[petsc-users] Solving A*X = B where A and B are matrices
Sat Dec 1 17:03:33 CST 2012
    We recommend following the directions http://www.mcs.anl.gov/petsc/documentation/faq.html#schurcomplement  for computing a Schur complement; just skip the unneeded step. MUMPS supports a parallel Cholesky but you can also use a parallel LU with MUMPS, PaSTIX or SuperLU_Dist and those will work fine also. With current software Cholesky in parallel is not tons better than LU so generally not worth monkeying with.
   Barry
On Dec 1, 2012, at 12:05 PM, Jelena Slivka <slivkaje at gmail.com> wrote:
> Hello!
> I am trying to solve A*X = B where A and B are matrices, and then find trace of the resulting matrix X. My approach has been to partition matrix B in column vectors bi and then solve each system A*xi = bi. Then, for all vectors xi I would extract i-th element xi(i) and sum those elements in order to get Trace(X).
> Pseudo-code:
> 1) load matrices A and B
> 2) transpose matrix B (so that each right-hand side bi is in the row, as operation MatGetColumnVector is slow)
> 3) set up KSPSolve
> 4) create vector diagonal (in which xi(i) elements will be stored)
> 5) for each row i of matrix B owned by current process:
>           - create vector bi by extracting row i from matrix B
>           - apply KSPsolve to get xi
>           - insert value xi(i) in diagonal vector (only the process which
>             holds the ith value of vector x(i) should do so)
> 6) sum vector diagonal to get the trace.
> However, my code (attached, along with the test case) runs fine on one process, but hangs if started on multiple processes. Could you please help me figure out what am I doing wrong?
> Also, could you please tell me is it possible to use Cholesky factorization when running on multiple processes (I see that I cannot use it when I set the format of matrix A to MPIAIJ)?
> <Experiment.c><Abin><Bbin>
