[petsc-users] Nullspace for a coupled system of equations
Fri Aug 17 09:24:05 CDT 2012
On Fri, Aug 17, 2012 at 3:10 AM, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> I want to solve some (weakly) coupled system of equations of the following
> form:
> A  B     u
> 0  C     v
> so, C is the discrete Laplacian and A and B are some more complicated
> operators (I make use of linear finite elements). All boundary conditions
> are periodic, so the unknown v is determined only up to a constant. A and B
> contain both the identity operator, so u is fixed. Now I want to solve the
> system on the whole (there are reasons to do it in this way!) and I must
> provide information about the nullspace to the solver. When I am right, to
> provide the correct nullspace I must solve one equation with A. Is there
> any way in PETSc to circumvent the problem?
If I understand you correctly, your null space vector is (0 I). I use the
same null space for SNES ex62.
Note that you should probably use FieldSplit multiplicative here since you
have a block triangular system to start with.
   Matt
> Thomas
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/a1c5c254/attachment.html>
