[petsc-users] How to change KSP tolerance during SNES steps
Thu Apr 26 14:57:45 CDT 2012
On Apr 26, 2012, at 10:31 AM, behzad baghapour wrote:
> Thanks. It did work!
> Then how I should do for changing the tolerance of ksp? (changing from inexact into exact Newton phase)
> Thanks a lot,
  Hong already answered that
behzad :
I set SNES with -snes_ksp_ew to solve the system with inexact method. I want to reset the SNES into exact Newton with changing the KSP rtol at final iterations (in full Newton phase). How can I reset the KSP tolerance after specific iterations of SNES?
You can use SNESMonitorSet() and write your own monitor function to do this:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESMonitorSet.html
Hong
