[petsc-users] ex52_integrateElement.cu
Wed Apr 25 13:06:09 CDT 2012
On Wed, Apr 25, 2012 at 1:50 PM, David Fuentes <fuentesdt at gmail.com> wrote:
> I'm pretty sure I pulled the latest on this petsc-dev and Generator, but
> when i change GPU type to PetscReal or double, i'm getting key errors ?
Ah well, I was getting around to fixing this. The problem is a little
deeper.  The C version uses pointers everywhere to be
general, but I was using the CUDA types since I thought the compiler would
be more aggressive even though it is
limiting. However, despite having float1, float2, float3, and float4, CUDA
provides only double2. I do all my tests in float.
I will fix this after the baby goes down and mail back.
     Matt
hg diff
> diff -r 4a642f9b7b70 config/PETSc/FEM.py
> --- a/config/PETSc/FEM.py       Wed Apr 25 02:13:29 2012 -0500
> +++ b/config/PETSc/FEM.py       Wed Apr 25 12:39:03 2012 -0500
> @@ -434,7 +434,7 @@
>      from Cxx import Define, Declarator
>      dim  = element.get_reference_element().get_spatial_dimension()
>      ext  = '_'+str(num)
> -    real = 'float'
> +    real = 'PetscReal'
> SCRGP2$ python $PETSC_DIR//bin/pythonscripts/PetscGenerateFEMQuadrature.py
> 3 1 1 1 laplace ex52.h
> [{(-1.0, -1.0, -1.0): [(1.0, ())]}, {(1.0, -1.0, -1.0): [(1.0, ())]},
> {(-1.0, 1.0, -1.0): [(1.0, ())]}, {(-1.0, -1.0, 1.0): [(1.0, ())]}]
> {0: {0: [0], 1: [1], 2: [2], 3: [3]}, 1: {0: [], 1: [], 2: [], 3: [], 4:
> [], 5: []}, 2: {0: [], 1: [], 2: [], 3: []}, 3: {0: []}}
> Perm: [0, 1, 2, 3]
> Creating /home/fuentes/tutorials/ex52.h
> Traceback (most recent call last):
>   File
> "/opt/apps/PETSC/petsc-dev//bin/pythonscripts/PetscGenerateFEMQuadrature.py",
> line 31, in <module>
>     generator.run(elements, numBlocks, operator, filename)
>   File "/opt/apps/PETSC/petsc-dev/config/PETSc/FEM.py", line 977, in run
>     self.outputElementSource(self.getElementSource(elements, numBlocks,
> operator, sourceType = 'GPU'),
> os.path.splitext(filename)[0]+'_gpu'+os.path.splitext(filename)[1])
>   File "/opt/apps/PETSC/petsc-dev/config/PETSc/FEM.py", line 936, in
> getElementSource
>     defns.extend(self.getComputationTypes(element, n))
>   File "/opt/apps/PETSC/petsc-dev/config/PETSc/FEM.py", line 450, in
> getComputationTypes
>     vecType.type       = self.Cxx.typeMap[real+str(dim)]
> KeyError: 'PetscReal3'
> do I need to add something like below ?
> cd externalpackages/Generator/; hg diff
> diff -r 361a2eec9c01 CxxHelper.py
> --- a/CxxHelper.py      Tue Mar 27 09:01:27 2012 -0500
> +++ b/CxxHelper.py      Wed Apr 25 12:39:12 2012 -0500
> @@ -98,6 +98,11 @@
>      cxxType.identifier = 'float'
>      cxxType.baseType = True
>      cxxType.const = True
> +    typeMap['double3'] = cxxType
> +    cxxType = Type()
> +    cxxType.identifier = 'double'
> +    cxxType.baseType = True
> +    cxxType.const = True
>      typeMap['const float1'] = cxxType
>      cxxType = Type()
>      cxxType.identifier = 'float2'
> On Mon, Apr 2, 2012 at 9:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Mar 28, 2012 at 6:42 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Wed, Mar 28, 2012 at 6:25 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>> Yes. This would work.
>>>> I had trouble compiling in single precision using the some of the
>>>> external package options I was using for double.
>>> Okay,  getting on it now.
>> Okay, I have tested using PetscReal=double with floats on the GPU. If you
>> want doubles on the GPU, you can
>> currently change PETSc/FEM.py:434. I am deciding what the best way to
>> specify this type is.
>>   Thanks,
>>      Matt
>>>    Matt
>>>> On Wed, Mar 28, 2012 at 4:57 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Wed, Mar 28, 2012 at 4:12 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>>> works!
>>>>> Excellent. Now, my thinking was that GPUs are most useful doing single
>>>>> work, but
>>>>> I can see the utility of double accuracy for a residual.
>>>>> My inclination is to define another type, say GPUReal, and use it for
>>>>> all kernels.
>>>>> Would that do what you want?
>>>>>    Matt
>>>>>> SCRGP2$ make ex52
>>>>>> /usr/bin/mpicxx -o ex52.o -c -O0 -g -fPIC
>>>>>> -I/opt/apps/PETSC/petsc-dev/include
>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/include
>>>>>> -I/opt/apps/cuda/4.0/cuda/include -I/usr/include -I/usr/include/mpich2
>>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>>>>>> nvcc -G -O0 -g -arch=sm_10  -c --compiler-options="-O0 -g   -fPIC
>>>>>>  -D__INSDIR__=src/snes/examples/tutorials/"  ex52_integrateElement.cu
>>>>>>  ex52_gpu_inline.h(7): warning: variable "points_0" was declared but
>>>>>> never referenced
>>>>>> ex52_gpu_inline.h(21): warning: variable "Basis_0" was declared but
>>>>>> never referenced
>>>>>> never referenced
>>>>>> ex52_gpu_inline.h(13): warning: variable "weights_0" was declared but
>>>>>> never referenced
>>>>>> never referenced
>>>>>> ex52_gpu_inline.h(28): warning: variable "BasisDerivatives_0" was
>>>>>> declared but never referenced
>>>>>> never referenced
>>>>>> never referenced
>>>>>> never referenced
>>>>>> never referenced
>>>>>> never referenced
>>>>>> /usr/bin/mpicxx -O0 -g   -o ex52 ex52.o ex52_integrateElement.o
>>>>>>  -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/lib
>>>>>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/lib
>>>>>>  -lpetsc
>>>>>> -ltriangle -lX11 -lpthread -lmetis -Wl,-rpath,/opt/apps/cuda/4.0/cuda/lib64
>>>>>> -L/opt/apps/cuda/4.0/cuda/lib64 -lcufft -lcublas -lcudart -lcusparse
>>>>>> -Wl,-rpath,/opt/epd-7.1-2-rh5-x86_64/lib -L/opt/epd-7.1-2-rh5-x86_64/lib
>>>>>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5
>>>>>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>>>>>> -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -ldl -lmpich -lopa -lpthread -lrt
>>>>>> -lgcc_s -lmpichf90 -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx
>>>>>> -lstdc++ -ldl -lmpich -lopa -lpthread -lrt -lgcc_s -ldl
>>>>>> SCRGP2$ ./ex52 -dim 2 -compute_function -show_residual -batch -gpu
>>>>>> GPU layout grid(1,2,1) block(3,1,1) with 1 batches
>>>>>>  N_t: 3, N_cb: 1
>>>>>> Residual:
>>>>>> Vector Object: 1 MPI processes
>>>>>>   type: seq
>>>>>> -0.25
>>>>>> -0.5
>>>>>> 0.25
>>>>>> -0.5
>>>>>> -1
>>>>>> 0.5
>>>>>> 0.25
>>>>>> 0.5
>>>>>> 0.75
>>>>>> Residual:
>>>>>>   type: seq
>>>>>> -0.25
>>>>>> -0.5
>>>>>> 0.25
>>>>>> -0.5
>>>>>> -1
>>>>>> 0.5
>>>>>> 0.25
>>>>>> 0.5
>>>>>> 0.75
>>>>>> On Wed, Mar 28, 2012 at 1:37 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>>>> sure. will do.
>>>>>>> On Wed, Mar 28, 2012 at 1:23 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Wed, Mar 28, 2012 at 1:14 PM, David Fuentes <fuentesdt at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> thanks! its running, but I seem to be getting different answer for
>>>>>>>>> cpu/gpu ?
>>>>>>>>> i had some floating point problems on this Tesla M2070 gpu before,
>>>>>>>>> but adding the '-arch=sm_20' option seemed to fix it last time.
>>>>>>>>> is the assembly in single precision ? my 'const PetscReal
>>>>>>>>> jacobianInverse' being passed in are doubles
>>>>>>>> Yep, that is the problem. I have not tested anything in double. I
>>>>>>>> have not decided exactly how to handle it. Can you
>>>>>>>> make another ARCH --with-precision=single and make sure it works,
>>>>>>>> and then we can fix the double issue?
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>>  N_t: 3, N_cb: 1
>>>>>>>>> Residual:
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> 755712
>>>>>>>>> 0
>>>>>>>>> -58720
>>>>>>>>> -2953.13
>>>>>>>>> 0.375
>>>>>>>>> 1.50323e+07
>>>>>>>>> 0.875
>>>>>>>>> 0
>>>>>>>>> SCRGP2$
>>>>>>>>> Residual:
>>>>>>>>>   type: seq
>>>>>>>>> -0.25
>>>>>>>>> -0.5
>>>>>>>>> 0.25
>>>>>>>>> -0.5
>>>>>>>>> -1
>>>>>>>>> 0.5
>>>>>>>>> 0.25
>>>>>>>>> 0.5
>>>>>>>>> 0.75
>>>>>>>>> On Wed, Mar 28, 2012 at 11:55 AM, Matthew Knepley <
>>>>>>>>>> On Wed, Mar 28, 2012 at 11:45 AM, David Fuentes <
>>>>>>>>>>> The example seems to be running on cpu with '-batch' but
>>>>>>>>>>> i'm getting errors in line 323 with the '-gpu' option
>>>>>>>>>>> [0]PETSC ERROR: IntegrateElementBatchGPU() line 323 in
>>>>>>>>>>> src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>>>>>>>> should this possibly be PetscScalar ?
>>>>>>>>>> No.
>>>>>>>>>>> -  ierr = cudaMalloc((void**) &d_coefficients,         Ne*N_bt *
>>>>>>>>>>> sizeof(float));CHKERRQ(ierr);
>>>>>>>>>>> +  ierr = cudaMalloc((void**) &d_coefficients,         Ne*N_bt *
>>>>>>>>>>> sizeof(PetscScalar));CHKERRQ(ierr);
>>>>>>>>>>> SCRGP2$ python
>>>>>>>>>>> $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py 2 1 1 1
>>>>>>>>>>> laplacian ex52.h
>>>>>>>>>>> ['/opt/apps/PETSC/petsc-dev/bin/pythonscripts/PetscGenerateFEMQuadrature.py',
>>>>>>>>>>> '2', '1', '1', '1', 'laplacian', 'ex52.h']
>>>>>>>>>>> 2 1 1 1 laplacian
>>>>>>>>>>> [{(-1.0, -1.0): [(1.0, ())]}, {(1.0, -1.0): [(1.0, ())]},
>>>>>>>>>>> {(-1.0, 1.0): [(1.0, ())]}]
>>>>>>>>>>> {0: {0: [0], 1: [1], 2: [2]}, 1: {0: [], 1: [], 2: []}, 2: {0:
>>>>>>>>>>> Perm: [0, 1, 2]
>>>>>>>>>>> Creating /home/fuentes/snestutorial/ex52.h
>>>>>>>>>>> Creating /home/fuentes/snestutorial/ex52_gpu.h
>>>>>>>>>>> Perm: [0, 1, 2]
>>>>>>>>>>> Creating /home/fuentes/snestutorial/ex52_gpu_inline.h
>>>>>>>>>>> SCRGP2$ make ex52
>>>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/include
>>>>>>>>>>> -I/opt/apps/cuda/4.1/cuda/include -I/opt/apps/PETSC/petsc-dev/include/sieve
>>>>>>>>>>> -I/opt/MATLAB/R2011a/extern/include -I/usr/include
>>>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/cbind/include
>>>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/forbind/include
>>>>>>>>>>> -I/usr/include/mpich2 -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>>>>>>>>>>> nvcc -O0 -g -arch=sm_20  -c --compiler-options="-O0 -g   -fPIC
>>>>>>>>>>> -I/usr/include/mpich2    -D__INSDIR__=src/snes/examples/tutorials/"
>>>>>>>>>>> was declared but never referenced
>>>>>>>>>>>  -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib
>>>>>>>>>>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib  -lpetsc
>>>>>>>>>>> -ltriangle -lX11 -lpthread -lsuperlu_dist_3.0 -lcmumps -ldmumps -lsmumps
>>>>>>>>>>> -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lscalapack -lblacs
>>>>>>>>>>> -Wl,-rpath,/opt/apps/cuda/4.1/cuda/lib64 -L/opt/apps/cuda/4.1/cuda/lib64
>>>>>>>>>>> -Wl,-rpath,/opt/MATLAB/R2011a/sys/os/glnxa64:/opt/MATLAB/R2011a/bin/glnxa64:/opt/MATLAB/R2011a/extern/lib/glnxa64
>>>>>>>>>>> -L/opt/MATLAB/R2011a/bin/glnxa64 -L/opt/MATLAB/R2011a/extern/lib/glnxa64
>>>>>>>>>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>>>>>>>>>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5 -lexoIIv2for -lexodus
>>>>>>>>>>> -lnetcdf_c++ -lnetcdf -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>>>>>>>>>>> /bin/rm -f ex52.o ex52_integrateElement.o
>>>>>>>>>>> Residual:
>>>>>>>>>>>   type: seq
>>>>>>>>>>> -0.25
>>>>>>>>>>> -0.5
>>>>>>>>>>> 0.25
>>>>>>>>>>> -0.5
>>>>>>>>>>> -1
>>>>>>>>>>> 0.5
>>>>>>>>>>> 0.25
>>>>>>>>>>> 0.5
>>>>>>>>>>> 0.75
>>>>>>>>>>> -gpu
>>>>>>>>>>> [0]PETSC ERROR: FormFunctionLocalBatch() line 679 in
>>>>>>>>>>> src/snes/examples/tutorials/ex52.c
>>>>>>>>>>> [0]PETSC ERROR: SNESDMComplexComputeFunction() line 431 in
>>>>>>>>>>> src/snes/utils/damgsnes.c
>>>>>>>>>>> [0]PETSC ERROR: main() line 1021 in
>>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 35) - process 0
>>>>>>>>>> This is failing on cudaMalloc(), which means your card is not
>>>>>>>>>> available for running. Are you trying to run on your laptop?
>>>>>>>>>> If so, applications like Preview can lock up the GPU. I know of
>>>>>>>>>> no way to test this in CUDA while running. I just close
>>>>>>>>>> apps until it runs.
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> On Tue, Mar 27, 2012 at 8:37 PM, Matthew Knepley <
>>>>>>>>>>>> On Tue, Mar 27, 2012 at 2:10 PM, Blaise Bourdin <
>>>>>>>>>>>> bourdin at lsu.edu> wrote:
>>>>>>>>>>>>> On Mar 27, 2012, at 1:23 PM, Matthew Knepley wrote:
>>>>>>>>>>>>> On Tue, Mar 27, 2012 at 12:58 PM, David Fuentes <
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> I had a question about the status of example 52.
>>>>>>>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52.c
>>>>>>>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>>>>>>>>>>> Can this example be used with a DM object created from an
>>>>>>>>>>>>>> unstructured exodusII mesh, DMMeshCreateExodus, And the FEM assembly done
>>>>>>>>>>>>>> on GPU ?
>>>>>>>>>>>>> 1) I have pushed many more tests for it now. They can be run
>>>>>>>>>>>>> using the Python build system
>>>>>>>>>>>>>   ./config/builder2.py check src/snes/examples/tutorials/ex52.c
>>>>>>>>>>>>>   in fact, you can build any set of files this way.
>>>>>>>>>>>>> 2) The Exodus creation has to be converted to DMComplex from
>>>>>>>>>>>>> DMMesh. That should not take me very long. Blaise maintains that
>>>>>>>>>>>>>      so maybe there will be help :) You will just replace
>>>>>>>>>>>>> DMComplexCreateBoxMesh() with DMComplexCreateExodus(). If you request
>>>>>>>>>>>>>      it, I will bump it up the list.
>>>>>>>>>>>>> DMMeshCreateExodusNG is much more flexible
>>>>>>>>>>>>> than DMMeshCreateExodus in that it can read meshes with multiple element
>>>>>>>>>>>>> types and should have a much lower memory footprint. The code should be
>>>>>>>>>>>>> fairly easy to read. you can email me directly if you have specific
>>>>>>>>>>>>> questions. I had looked at creating a DMComplex and it did not look too
>>>>>>>>>>>>> difficult, as long as interpolation is not needed. I have plans to
>>>>>>>>>>>>> write DMComplexCreateExodus, but haven't had time too so far. Updating the
>>>>>>>>>>>>> Vec viewers and readers may be a bit more involved. In perfect world, one
>>>>>>>>>>>>> would write an EXODUS viewer following the lines of the VTK and HDF5 ones.
>>>>>>>>>>>> David and Blaise,  I have converted this function, now
>>>>>>>>>>>> DMComplexCreateExodus(). Its not tested, but I think
>>>>>>>>>>>> Blaise has some stuff we can use to test it.
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>>> Blaise
>>>>>>>>>>>>> Let me know if you can run the tests.
>>>>>>>>>>>>>   Thanks
>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> David
>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> Department of Mathematics and Center for Computation &
>>>>>>>>>>>>> Technology
>>>>>>>>>>>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>>>>>>>>>>>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
>>>>>>>>>>>>> http://www.math.lsu.edu/~bourdin
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120425/a67ec439/attachment-0001.htm>
