[petsc-users] error in petsc-dev
Mohammad Mirzadeh mirzadeh at gmail.com
Tue Apr 24 18:53:51 CDT 2012
Hong,
Is this also true with MatSetType()? petsc-dev seems to need it (3.2-p6
does not) but it's not listed in the changes link ...
On Tue, Apr 24, 2012 at 4:27 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Thanks Hong.
> On Tue, Apr 24, 2012 at 4:25 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>> See
>> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html:
>> You MUST now call MatXXXSetPreallocation() or MatSetUp() on any matrix
>> you create directly (not using DMCreateMatrix()) before calling
>> MatSetValues(), MatSetValuesBlocked() etc.
>> On Tue, Apr 24, 2012 at 6:01 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>> Hi,
>>> While trying to figure out a problem, I came across the following
>>> situation. Consider the following code:
>>> int main (int argc, char **argv){
>>>     PetscInitialize(&argc, &argv, (char*)0, help);
>>>     Mat m;
>>>     MatCreate(PETSC_COMM_WORLD, &m);
>>>     MatSetSizes(m, 10, 10, PETSC_DECIDE, PETSC_DECIDE);
>>>     MatSetFromOptions(m);
>>>     MatAssemblyBegin(m, MAT_FINAL_ASSEMBLY);
>>>     MatAssemblyEnd(m, MAT_FINAL_ASSEMBLY);
>>>     MatView(m, PETSC_VIEWER_STDOUT_WORLD);
>>>     MatDestroy(&m);
>>>     PetscFinalize();
>>>     return 0;
>>> This runs without any problem under 3.2-p6 but fails with petsc-dev:
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Object is in wrong state!
>>> [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
>>> argument 1 "mat" before MatAssemblyBegin()!
>>> [0]PETSC ERROR:
>>> Eventually I could fix this by adding MatSetUp(m) after setting the
>>> options. Why do I need this in petsc-dev? Does this somehow preallocate the
>>> matrix?
>> Yes.
>> Hong
>>> Thanks,
>>> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120424/72daf2ac/attachment.htm>
