[petsc-users] Problem with fortran version of ex29 in ksp
Tue Apr 24 17:06:43 CDT 2012
On Tue, Apr 24, 2012 at 4:57 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>  Hi,
> I still got the same error the moment this subroutine is called, after
> changing to :
> call
> MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_OBJECT,nullspace,ierr)
Argument 3 should be 0.
  Matt
> [0]PETSC ERROR: Null argument, when expecting valid pointer!
> [0]PETSC ERROR: Null Object: Parameter # 4!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development HG revision:
> fc934c1d84bc6ba8e2686702a8a99539d
> 50af122  HG Date: Mon Apr 23 11:39:32 2012 -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: c:\obj_tmp\ex29f\Debug\ex29f.exe on a petsc-3.2 named
> USER-PC by
>  User Tue Apr 24 22:54:50 2012
> [0]PETSC ERROR: Libraries linked from
> /cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
> /lib
> [0]PETSC ERROR: Configure run at Mon Apr 23 21:45:20 2012
> [0]PETSC ERROR: Configure options --with-cc="win32fe cl"
> --with-fc="win32fe ifor
> t" --with-cxx="win32fe cl" --with-mpi-dir=/cygdrive/d/Lib/MPICH2/
> --download-f-b
> las-lapack=1 --prefix=/cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
> --with-debuggin
> g=1 --useThreads=0
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatNullSpaceCreate() line 250 in
> src/mat/interface/C:\temp\PETSC
> -~1\src\mat\INTERF~1\matnull.c
> Yours sincerely,
> TAY wee-beng
> On 24/4/2012 10:37 PM, Matthew Knepley wrote:
> On Tue, Apr 24, 2012 at 4:32 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>  Hi,
>> I'm trying to rewrite ex29 (KSP^Laplacian, 2d) from c to fortran version.
>> The fortran version is based on the template of ex22f, which is in 3d.
>> I have attached the code below. I have 2 problems.
>> 1. When i3 = -3, in dirichlet BC, I got the same answer as ex29 in c
>> version.
>> However, when I change i3 to -4, I got the following error:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Argument out of range!
>> [0]PETSC ERROR: New nonzero at (9,1) caused a malloc!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR:
>> USER-PC by
>>  User Tue Apr 24 22:08:46 2012
>> /lib
>> --download-f-b
>> --with-debuggin
>> g=1 --useThreads=0
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: MatSetValues_SeqAIJ() line 331 in
>> src/mat/impls/aij/seq/C:\temp\
>> PETSC-~1\src\mat\impls\aij\seq\aij.c
>> [0]PETSC ERROR: MatSetValues() line 1148 in
>> src/mat/interface/C:\temp\PETSC-~1\s
>> rc\mat\INTERF~1\matrix.c
>> [0]PETSC ERROR: MatSetValuesLocal() line 2003 in
>> -~1\src\mat\INTERF~1\matrix.c
>> [0]PETSC ERROR: MatSetValuesStencil() line 1379 in
>> SC-~1\src\mat\INTERF~1\matrix.c
>> [0]PETSC ERROR: New nonzero at (10,2) caused a malloc!
>> What did I do wrong?
>> 2. When I wanted to use the neumann BC, following ex29, I added :
>> In subroutine ComputeRHS
>> call
>> MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,nullspace,ierr)
>> call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>> call MatNullSpaceDestroy(nullspace,ierr)
>> and in subroutine ComputeMatrix
>> call
>> call MatSetNullSpace(jac,nullspace,ierr)
>> When I compile, it says unresolved external symbol MatNullSpaceRemove.
>> Removing MatNullSpaceRemove, I can compile but running gives the error:
>> [0]PETSC ERROR: Corrupt argument:
>> see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind!
>> [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 4!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR:
>> USER-PC by
>>  User Tue Apr 24 22:30:31 2012
>> /lib
>> --download-f-b
>> --with-debuggin
>> g=1 --useThreads=0
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Invalid argument!
>> [0]PETSC ERROR: Wrong type of object: Parameter # 1!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR:
>> USER-PC by
>> /lib
>> --download-f-b
>> --with-debuggin
>> g=1 --useThreads=0
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: MatNullSpaceDestroy() line 305 in
>> C-~1\src\mat\INTERF~1\matnull.c
>> [0]PETSC ERROR: ourdmfunction() line 30 in
>> src/dm/interface/ftn-custom/C:\temp\P
>> ETSC-~1\src\dm\INTERF~1\FTN-CU~1\zdmf.c
>> [0]PETSC ERROR: DMComputeFunction() line 1783 in
>> src/dm/interface/C:\temp\PETSC-
>> ~1\src\dm\INTERF~1\dm.c
>> [0]PETSC ERROR: KSPSetUp() line 218 in
>> src/ksp/ksp/interface/C:\temp\PETSC-~1\sr
>> c\ksp\ksp\INTERF~1\itfunc.c
>> [0]PETSC ERROR:
>> [0]PETSC ERROR:
>> USER-PC by
>> /lib
>> --download-f-b
>> --with-debuggin
>> g=1 --useThreads=0
>> [0]PETSC ERROR:
>> [0]PETSC ERROR:
>> [0]PETSC ERROR:
>> USER-PC by
>> /lib
>> --download-f-b
>> --with-debuggin
>> g=1 --useThreads=0
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: KSPSolve() line 402 in
>> Vector Object:Vec_0000000084000000_0 1 MPI processes
>>   type: mpi
>> Process [0]
>> What's wrong?
>> *program ex29f*
>> implicit none
>> !                    Include files
>> !     petscsys.h  - base PETSc routines      petscvec.h - vectors
>> !     petscmat.h - matrices
>> !     petscksp.h    - Krylov subspace methods  petscpc.h  -
>> preconditioners
>> #include "finclude/petsc.h90"
>> PetscErrorCode   ierr
>> DM               da
>> KSP              ksp
>> Vec              x
>> external         ComputeRHS,ComputeMatrix
>> PetscInt i1,i3
>> call  PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>> i3 = -4
>> i1 = 1
>> call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
>> call
>> DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>> call DMSetFunction(da,ComputeRHS,ierr)
>> call DMSetJacobian(da,ComputeMatrix,ierr)
>> call KSPSetDM(ksp,da,ierr)
>> call KSPSetFromOptions(ksp,ierr)
>> call KSPSetUp(ksp,ierr)
>> call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>> call KSPGetSolution(ksp,x,ierr)
>> call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
>> call KSPDestroy(ksp,ierr)
>> call DMDestroy(da,ierr)
>> call PetscFinalize(ierr)
>> end program ex29f
>> subroutine ComputeRHS(da,x,b,ierr)
>> implicit none
>> PetscErrorCode  ierr
>> PetscInt i,j,mx,my,xm,ym,xs,ys
>> PetscScalar  h,nu,rho
>> PetscScalar Hx,Hy
>> PetscScalar,pointer :: array(:,:)
>> Vec          x,b
>> DM           da
>> MatNullSpace nullspace    !>neumann BC
>> nu = 0.1
>> call
>> DMDAGetInfo(da,PETSC_NULL_INTEGER,mx,my,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
>> Hx = 1.d0 / (mx-1)
>> Hy = 1.d0 / (my-1)
>> call
>> DMDAGetCorners(da,xs,ys,PETSC_NULL_INTEGER,xm,ym,PETSC_NULL_INTEGER,ierr)
>> call DMDAVecGetArrayF90(da,b,array,ierr)
>> do j = ys,ys+ym-1
>>     do i = xs,xs+xm-1
>>         array(i,j) = exp(-(i*Hx)*(i*Hx)/nu)*exp(-(j*Hy)*(j*Hy)/nu)*Hx*Hy
>>     end do
>> end do
>> call DMDAVecRestoreArrayF90(da,b,array,ierr)
>> call VecAssemblyBegin(b,ierr)
>> call VecAssemblyEnd(b,ierr)
>> !call
>  4th argument should be PETSC_NULL_OBJECT.
>     Matt
>>  !call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>> !call MatNullSpaceDestroy(nullspace,ierr)
>> end subroutine ComputeRHS
>> subroutine ComputeMatrix(da,x,JJ,jac,str,ierr)
>> implicit none
>> Mat          jac,JJ
>> PetscErrorCode    ierr
>> DM           da
>> PetscInt    i,j,k,mx,my,xm
>> PetscInt    ym,xs,ys,i1,i5
>> PetscScalar  v(5),Hx,Hy,rho,centerRho
>> PetscScalar  HydHx
>> PetscScalar  HxdHy
>> MatStencil   row(4),col(4,5)
>> Vec          x
>> MatStructure str
>> rho = 1.0
>> i1 = 1
>> i5 = 5
>> centerRho = rho
>> call
>> Hx = 1.d0 / (mx-1)
>> Hy = 1.d0 / (my-1)
>> HxdHy = Hx/Hy
>> HydHx = Hy/Hx
>> call
>> do j=ys,ys+ym-1
>>     do i=xs,xs+xm-1
>>         row(MatStencil_i) = i
>>         row(MatStencil_j) = j
>>         call ComputeRho(i,j,mx,my,centerRho,rho)
>>         if (i.eq.0 .or. j.eq.0 .or. i.eq.mx-1 .or. j.eq.my-1) then
>>             v(1) = 2.0*rho*(HxdHy + HydHx)
>>             call
>> MatSetValuesStencil(jac,i1,row,i1,row,v,INSERT_VALUES,ierr)
>>         else
>>             v(1) = -rho*HxdHy
>>             col(MatStencil_i,1) = i
>>             col(MatStencil_j,2) = j-1
>  Cut and paste error above.
>    Matt
>>              v(2) = -rho*HydHx
>>             col(MatStencil_i,2) = i-1
>>             v(3) = 2.0*rho*(HxdHy + HydHx)
>>             col(MatStencil_i,3) = i
>>             col(MatStencil_j,3) = j
>>             v(4) = -rho*HydHx
>>             col(MatStencil_i,4) = i+1
>>             col(MatStencil_j,4) = j
>>             v(5) = -rho*HxdHy
>>             col(MatStencil_i,5) = i
>>             col(MatStencil_j,5) = j+1
>>             call
>> MatSetValuesStencil(jac,i1,row,i5,col,v,INSERT_VALUES,ierr)
>>         end if
>>     end do
>> end do
>> call MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY,ierr)
>> call MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY,ierr)
>> !call
>> !call MatSetNullSpace(jac,nullspace,ierr)
>> end subroutine ComputeMatrix
>> subroutine ComputeRho(i,j,mx,my,centerRho,rho)
>> PetscInt    i,j,mx,my
>> PetscScalar  rho,centerRho
>> if ((i > mx/3.0) .and. (i < 2.0*mx/3.0) .and. (j > my/3.0) .and. (j <
>> 2.0*my/3.0)) then
>>     rho = centerRho
>> else
>>     rho = 1.0
>> end if
>> end subroutine ComputeRho
>> Yours sincerely,
>> TAY wee-beng
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120424/4048f55b/attachment-0001.htm>
