[petsc-users] mumps get stuck with parmetis
Alexander Grayver agrayver at gfz-potsdam.de
Tue Apr 24 14:22:51 CDT 2012
Aron,
This parameter let's to see mumps output in console. The important this to understand where mumps hangs, during analysis, factorization or actual solution (substitutions)? I'm almost sure it's factorization step. I observe this pretty often with mumps compiled with petsc (whereas when mumps is used directly it's quite rare to come along with this problem).
Alexander
----- Reply message -----
From: "Aron Ahmadia" <aron.ahmadia at kaust.edu.sa>
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Subject: [petsc-users] mumps get stuck with parmetis
Date: Tue, Apr 24, 2012 21:13
I'm not sure if this is related, but Parmetis+Mumps+PETSc 3.2 on BlueGene/P was causing similar behavior without even setting any options.  The only way I was able to get a direct solver going was by switching over to SuperLU.
A
On Tue, Apr 24, 2012 at 10:01 PM, Alexander Grayver <agrayver at gfz-potsdam.de> wrote:
Can you set:
-mat_mumps_icntl_4 1
And send mumps output?
Also do you use lu or ilu? How large is your matrix?
Alexander
To: <petsc-users at mcs.anl.gov>
Date: Tue, Apr 24, 2012 19:43
My code will hang at the solving stage when I use mumps with the runtime option -mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2. If I remove these two options, my code works fine. I am using PETSc 3.2 and configure it with --download-mumps=1 and --download-parmetis=1. Could anyone give me any hints? Thanks.
Wen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120424/2db311da/attachment.htm>
