[petsc-users] Questions abt ex22f
TAY wee-beng zonexo at gmail.com
Sun Apr 22 14:30:48 CDT 2012
Sorry for the mistake. I tried again, changing to "call VecView(x,0,ierr)"
but still got the same error:
[wtay at hpc12:tutorials]$ ./ex22f
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] VecView line 735
/home/wtay/Codes/petsc-3.2-p5/src/vec/vec/interface/vector.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex22f on a arch-linu named hpc12 by wtay Sun Apr 22
21:25:01 2012
[0]PETSC ERROR: Libraries linked from
/home/wtay/Lib/petsc-3.2-p5_mumps_debug/lib
[0]PETSC ERROR: Configure run at Sun Nov 27 15:39:26 2011
[0]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-1.5.3/
--with-blas-lapack-dir=/opt/intel_xe_2011/mkl/lib/intel64/
--with-debugging=1 --download-hypre=1
--prefix=/home/wtay/Lib/petsc-3.2-p5_mumps_debug COPTFLAGS=-O0
FOPTFLAGS=-O0 --download-mumps=1 --download-parmetis=1
--download-scalapack=1 --download-blacs=1
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Yours sincerely,
TAY wee-beng
On 22/4/2012 9:20 PM, Jed Brown wrote:
> Look at the man page for VecView, it needs a PetscViewer argument.
> On Apr 22, 2012 2:19 PM, "TAY wee-beng" <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I have attached the ex22f.F file. The changes I added are given in
>     bold:
>     PetscErrorCode   ierr
>           DM               da
>           KSP              ksp
>     *Vec              x,b*
>           external         ComputeRHS,ComputeMatrix
>     call KSPSetUp(ksp,ierr)
>           call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>     *call KSPGetSolution(ksp,x,ierr)
>           call VecView(x,ierr)*
>           call KSPDestroy(ksp,ierr)
>           call DMDestroy(da,ierr)
>     The error is:
>     [0]PETSC ERROR:
>     Violation, probably memory access out of range
>     to find memory corruption errors
>     available,
>     function
>     [0]PETSC ERROR:
>     13:45:54 CDT 2011
>     [0]PETSC ERROR:
>     22 21:11:39 2012
>     [0]PETSC ERROR:
>     directory unknown file
>     with errorcode 59.
>     Yours sincerely,
>     TAY wee-beng
>     On 22/4/2012 9:06 PM, Jed Brown wrote:
>>     Run in a debugger and/or use --with-debugging=1 so that the error
>>     trace has more information. You could also show us the exact code
>>     that you used.
>>     On Apr 22, 2012 2:03 PM, "TAY wee-beng" <zonexo at gmail.com
>>         Hi,
>>         I added "Vec x,b" after "KSP ksp"
>>         and then "call KSPGetSolution(ksp, x, ierr)"
>>         I wanted to see the output so I added "call VecView(x,ierr)"
>>         but I got this error:
>>         [0]PETSC ERROR:
>>         OS X to find memory corruption errors
>>         [0]PETSC ERROR: configure using --with-debugging=yes,
>>         recompile, link, and run
>>         [0]PETSC ERROR: to get more information on the crash.
>>         [0]PETSC ERROR:
>>         29 13:45:54 CDT 2011
>>         shooting.
>>         [0]PETSC ERROR:
>>         Sun Apr 22 21:02:14 2012
>>         /home/wtay/Lib/petsc-3.2-p5_mumps_rel/lib
>>         [0]PETSC ERROR: Configure run at Sun Nov 27 15:18:15 2011
>>         --with-debugging=0 --download-hypre=1
>>         --prefix=/home/wtay/Lib/petsc-3.2-p5_mumps_rel COPTFLAGS=-O3
>>         FOPTFLAGS=-O3 --download-mumps=1 --download-parmetis=1
>>         [0]PETSC ERROR:
>>         with errorcode 59.
>>         Yours sincerely,
>>         TAY wee-beng
>>         On 22/4/2012 2:53 PM, Matthew Knepley wrote:
>>>         On Sun, Apr 22, 2012 at 3:31 AM, TAY wee-beng
>>>         <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>             Hi,
>>>             I am using petsc-dev 2012-04-20.
>>>             Btw, I'm referring to :
>>>             http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex22f.F.html
>>>             Part of the code is :
>>>             call KSPSetFromOptions(ksp,ierr)
>>>                    call PetscFinalize(ierr)
>>>             Unlike other codes like ex29c or ex45c, there isn't a
>>>             "call KSPGetSolution(ksp,x,ierr)"
>>>         You need to declare "Vec x", and then you can call
>>>            Matt
>>>             Also I want to add "call VecView(x,ierr)" to print out
>>>             the results, which is usally added after the above.
>>>             Thank you
>>>             Yours sincerely,
>>>             TAY wee-beng
>>>             On 22/4/2012 1:14 AM, Matthew Knepley wrote:
>>>>             On Sat, Apr 21, 2012 at 6:31 PM, TAY wee-beng
>>>>                 Hi,
>>>>                 May I know if ex22f is complete? I can't find :
>>>>                 If I entered it, it says x not found.
>>>>             This is correct in petsc-dev. What version are you using?
>>>>               Thanks,
>>>>                 Matt
>>>>                 Thank you!
>>>>                 Yours sincerely,
>>>>                 TAY wee-beng
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120422/591a0d2d/attachment.htm>
