[petsc-users] Questions abt ex22f
Sun Apr 22 14:20:48 CDT 2012
Look at the man page for VecView, it needs a PetscViewer argument.
On Apr 22, 2012 2:19 PM, "TAY wee-beng" <zonexo at gmail.com> wrote:
>  Hi,
> I have attached the ex22f.F file. The changes I added are given in bold:
> PetscErrorCode   ierr
>       DM               da
>       KSP              ksp
>      * Vec              x,b*
>       external         ComputeRHS,ComputeMatrix
> call KSPSetUp(ksp,ierr)
>       call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>       *call KSPGetSolution(ksp,x,ierr)
>       call VecView(x,ierr)*
>       call KSPDestroy(ksp,ierr)
>       call DMDestroy(da,ierr)
> The error is:
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
> ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find
> memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] VecView line 735
> /home/wtay/Codes/petsc-3.2-p5/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54
> CDT 2011
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./ex22f on a arch-linu named hpc12 by wtay Sun Apr 22
> 21:11:39 2012
> [0]PETSC ERROR: Libraries linked from
> /home/wtay/Lib/petsc-3.2-p5_mumps_debug/lib
> [0]PETSC ERROR: Configure run at Sun Nov 27 15:39:26 2011
> [0]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-1.5.3/
> --with-blas-lapack-dir=/opt/intel_xe_2011/mkl/lib/intel64/
> --with-debugging=1 --download-hypre=1
> --prefix=/home/wtay/Lib/petsc-3.2-p5_mumps_debug COPTFLAGS=-O0
> FOPTFLAGS=-O0 --download-mumps=1 --download-parmetis=1
> --download-scalapack=1 --download-blacs=1
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> Yours sincerely,
> TAY wee-beng
> On 22/4/2012 9:06 PM, Jed Brown wrote:
> Run in a debugger and/or use --with-debugging=1 so that the error trace
> has more information. You could also show us the exact code that you used.
> On Apr 22, 2012 2:03 PM, "TAY wee-beng" <zonexo at gmail.com> wrote:
>>  Hi,
>> I added "Vec x,b" after "KSP ksp"
>> and then "call KSPGetSolution(ksp, x, ierr)"
>> I wanted to see the output so I added "call VecView(x,ierr)" but I got
>> this error:
>> [0]PETSC ERROR:
>> find memory corruption errors
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>> and run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR:
>> CDT 2011
>> [0]PETSC ERROR:
>> 21:02:14 2012
>> /home/wtay/Lib/petsc-3.2-p5_mumps_rel/lib
>> [0]PETSC ERROR: Configure run at Sun Nov 27 15:18:15 2011
>> --with-debugging=0 --download-hypre=1
>> --prefix=/home/wtay/Lib/petsc-3.2-p5_mumps_rel COPTFLAGS=-O3 FOPTFLAGS=-O3
>> --download-mumps=1 --download-parmetis=1 --download-scalapack=1
>> --download-blacs=1
>> [0]PETSC ERROR:
>> unknown file
>> with errorcode 59.
>> Yours sincerely,
>> TAY wee-beng
>> On 22/4/2012 2:53 PM, Matthew Knepley wrote:
>> On Sun, Apr 22, 2012 at 3:31 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>  Hi,
>>> I am using petsc-dev 2012-04-20.
>>> Btw, I'm referring to :
>>> http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex22f.F.html
>>> Part of the code is :
>>> call KSPSetFromOptions(ksp,ierr)
>>>       call PetscFinalize(ierr)
>>> Unlike other codes like ex29c or ex45c, there isn't a "call
>>> KSPGetSolution(ksp,x,ierr)"
>>  You need to declare "Vec x", and then you can call KSPGetSolution(ksp,
>> x, ierr)
>>     Matt
>>>  Also I want to add "call VecView(x,ierr)" to print out the results,
>>> which is usally added after the above.
>>> Thank you
>>> Yours sincerely,
>>> TAY wee-beng
>>> On 22/4/2012 1:14 AM, Matthew Knepley wrote:
>>> On Sat, Apr 21, 2012 at 6:31 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> Hi,
>>>> May I know if ex22f is complete? I can't find :
>>>> If I entered it, it says x not found.
>>>  This is correct in petsc-dev. What version are you using?
>>>    Thanks,
>>>      Matt
>>>> Thank you!
>>>> Yours sincerely,
>>>> TAY wee-beng
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120422/5f11b897/attachment.htm>
