[petsc-users] Advice on OpenMP/PETSc mix
Mohammad Mirzadeh mirzadeh at gmail.com
Fri Apr 20 14:56:45 CDT 2012
> PETSc can use threads or the "HMPI" approach. We are in the process of
unifying the code for all the threading models, at which point PETSc will
be able to use your OpenMP threads.
Jed, does this mean (in future) PETSc can automatically recognize my OpenMP
threads  at the core level and use them for parallelization  even if the
binary is run as 1 MPI process/node?
> > On Apr 20, 2012 1:50 PM, "Mohammad Mirzadeh" <mirzadeh at gmail.com> wrote:
> >> Thanks Aron. That would work but at the cost of wasting idle cores when
> threads join and the rest of MPI-based code is running, correct?
> >> On Fri, Apr 20, 2012 at 11:44 AM, Aron Ahmadia <
> aron.ahmadia at kaust.edu.sa> wrote:
> >>>> If I use, say Np = 16 processes on one node, MPI is running 16
> versions of the code on a single node (which has 16 cores). How does OpenMP
> figure out how to fork? Does it fork a total of 16 threads/MPI process =
> 256 threads or is it smart to just fork a total of 16 threads/node = 1
> thread/core = 16 threads? I'm a bit confused here how the job is scheduled
> when MPI and OpenMP are mixed?
> >>> This is one important use for OMP_NUM_THREADS.   If you're trying to
> increase the amount of memory per process, you should map one process per
> node and set OMP_NUM_THREADS to the number of OpenMP threads you'd like.
>  There are lots of tutorials and even textbooks now that discuss hybrid
> programming techniques that you should look to for more information (or you
> could try scicomp.stackexchange.com).
> >>> Cheers,
> >>> Aron
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120420/611f8d39/attachment.htm>
