[petsc-users] A problem with MPI Derived Data Type and 'calloc'
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Thu Apr 19 09:18:45 CDT 2012
     TESTVAR ***a, ***b, ***c;
     TESTVAR **aa, **bb, **cc;
     TESTVAR *arraya, *arrayb, *arrayc;
     arraya = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
     arrayb = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
     arrayc = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
     aa =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
     bb =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
     cc =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
     for(i = 0; i < SIZE*SIZE; i++) {
       aa[i] = &arraya[i*SIZE];
       bb[i] = &arrayb[i*SIZE];
       cc[i] = &arrayc[i*SIZE];
     a =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
     b =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
     c =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
     for(i = 0; i < SIZE; i++) {
       a[i] = &aa[i*SIZE];
       b[i] = &bb[i*SIZE];
       c[i] = &cc[i*SIZE];
   It works. However, I wonder if there is any other good ideas for 3D
problem other than this kinda of 'two-layer' approach.
*_What is the reason for not using DMDA?_
*In 2D, I established a 2D array for data communication between nodes by
using MPI derived data type. It allows me to easily communicate both
contiguous (i.e. MPI_TYPE_CONTIGUOUS) and non-contiguous (i.e.
MPI_TYPE_VECTOR) data. That is why I use this similar approach in 3D,
though an additional data type, i.e. MPI_TYPE_INDEXED, need to be used.
Does DMDA have those type of function or derived data type?
    "2, I have a little question on PETSc about 3D processor ordering.
    Does PETSc have any function giving me the nodes/rank number of
    neighboring nodes/ranks? Are those 'Application Ordering' functions
    applicable for my case?"
_*What do you mean by neighboring? If it is jsut stencil neighbors, then
use a local vector.*_
When I send and receive data with MPI_Send and MPI_RECV, I need provide
the 'destination' (in MPI_Send refer
to'http://www.mcs.anl.gov/research/projects/mpi/www/www3/MPI_Send.html')
and 'source' (in MPI_RECV refer
to'http://www.mcs.anl.gov/research/projects/mpi/www/www3/MPI_Recv.html'). In
a 2D problem with Cartesian grid, 4 processes divide the whole domain to
4 sub-domain.
       2      |      3      |
       0      |      1      |
  Then, for node 1, the neighboring nodes are '0' and '3', which '0' is
the left node and '3' is the top node. I wonder if PETSc has any
function that I can call to obtain those neighboring nodes so that I do
not need to construct my function.
I'm sorry for confusing you.
thanks in advance,
Alan
On 4/19/2012 4:52 AM, Matthew Knepley wrote:
> On Wed, Apr 18, 2012 at 3:52 PM, Alan Wei <zhenglun.wei at gmail.com
> <mailto:zhenglun.wei at gmail.com>> wrote:
>     Dear all,
>         I hope you're having a nice day. I have a further question on
>     this issue in 3D.
>     1, Following the idea of Dr. Brown and Dr. Knepley, I finished a
>     2D test, which works very fine. Here, I did it in 3D by
>           a[i] = &aa[i*SIZE];
>           b[i] = &bb[i*SIZE];
>           c[i] = &cc[i*SIZE];
>     3D problem other than this kinda of 'two-layer' approach.
>     functions applicable for my case?
> use a local vector.
>    Matt
>     thanks,
>     Alan
>     On Fri, Apr 13, 2012 at 5:41 PM, Jed Brown <jedbrown at mcs.anl.gov
>     <mailto:jedbrown at mcs.anl.gov>> wrote:
>         On Fri, Apr 13, 2012 at 17:38, Zhenglun (Alan) Wei
>         <zhenglun.wei at gmail.com <mailto:zhenglun.wei at gmail.com>> wrote:
>                 I have a final question on it. Is it taken a lot of
>             memory for doing this? As I understand, pointers won't
>             occupy many memories and it works like an alias. It will
>             not, to my limit knowledge, take much extra memory by
>             doing this.
>         A pointer takes about as much space as a floating point value,
>         so that array of pointers costs about 1*N compared to the N*N
>         matrix.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120419/c9669ec4/attachment.htm>
