[petsc-users] ksp_monitor_true_residual_norm
Tue Apr 17 12:39:32 CDT 2012
On Tue, Apr 17, 2012 at 1:27 PM, Randall Mackie <rlmackie862 at gmail.com>wrote:
> Hi Barry,
> I've tried implementing this in Fortran, following ex2f.F in
> /src/ksp/ksp/examples/tutorials, but
> it is bombing out with the following message:
> ---------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Invalid argument!
> [0]PETSC ERROR: Wrong type of object: Parameter # 1!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54
> CDT 2011
> [0]PETSC ERROR:
> CDT 2011
> [1]PETSC ERROR: PetscViewerASCIIAddTab() line 277 in
> src/sys/viewer/impls/ascii/filev.c
> [1]PETSC ERROR: KSPMonitorTrueResidualNorm() line 233 in
> src/ksp/ksp/interface/iterativ.c
> [1]PETSC ERROR: ourmonitor() line 103 in
> src/ksp/ksp/interface/ftn-custom/zitfuncf.c
> [1]PETSC ERROR: KSPMonitor() line 1429 in src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: KSPSolve_CG() line 255 in src/ksp/ksp/impls/cg/cg.c
> [1]PETSC ERROR: KSPSolve() line 423 in src/ksp/ksp/interface/itfunc.c
> I am running PETSC 3.2-p5.
> I have set my monitor routine as follows:
>   subroutine ShellKSPMonitor(ksp, n, rnorm, dummy, ierr)
>   implicit none
> #include "finclude/petsc.h"
>   KSP :: ksp
>   PetscErrorCode :: ierr
>   PetscInt :: n, dummy
>   PetscReal :: rnorm
>   if (n == 200) then
>     call KSPMonitorTrueResidualNorm(ksp,n,rnorm,dummy,ierr)
I think it should work if dummy is 0, but we should really do NULL
conversion
here and you should pass PETSC_NULL.
   Matt
>   end if
>   return
>   end subroutine ShellKSPMonitor
> And then in the main program I call:
>   call KSPMonitorSet(ksp,ShellKSPMonitor,PETSC_NULL_OBJECT,
> PETSC_NULL_FUNCTION, ierr)
> As I have followed the example in the PETSc documentation, I am unsure
> where I have made a mistake.
> Thanks,
> Randy M
> On Fri, Apr 13, 2012 at 5:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Write a one line monitor that calls the true residual monitor when
>> desired:
>>    PetscErrorCode  myKSPMonitorTrueResidualNorm(KSP ksp,PetscInt
>> n,PetscReal rnorm,void *dummy)
>>        if (n % 10) {
>>           ierr =
>> KSPMonitorTrueResidualNorm(ksp,n,rnorm,dummy);CHKERRQ(ierr);
>>    then call this on the KPS
>>   ierr =
>> KSPMonitorSet(ksp,myKSPMonitorTrueResidualNorm,PETSC_VIEWER_STDOUT,0);CHKERRQ(ierr);
>> On Apr 13, 2012, at 6:52 PM, Randall Mackie wrote:
>> > In using ksp_monitor_true_residual_norm, is it possible to change how
>> often this information is printed out?
>> > That is, instead of every iteration, say I only want to see it every 10
>> or 20 iterations. Is there an easy way
>> > to do this, other than creating my own monitor and doing it myself?
>> > Thanks, Randy M.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120417/a778e32a/attachment.htm>
