[petsc-users] Complex Number - VecScale
Abdul Hanan Sheikh hanangul12 at yahoo.co.uk
Mon Apr 16 13:05:55 CDT 2012
Thanks! :)
I have an other query.
By using VecScale on vector "x" with scalar "alpha", it overwrites the vector "x" with "alpha \times x" .
Can we re-use the vector "x" after scaling ?
thanks,
Abdul
>________________________________
> From: Shri <abhyshr at mcs.anl.gov>
>To: Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk>; PETSc users list <petsc-users at mcs.anl.gov>
>Sent: Monday, 16 April 2012, 19:20
>Subject: Re: [petsc-users] Complex Number
>http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscOptionsGetScalar.html
>Dear users n devlopers,
>>My Petsc routine contans a complex number, as a parameter of my problem.
>>I need to provide it at the run time options, since I intend to test a variety of parameter.
>>In this regard, I read that PetscScalar is the way to declare a complex number.
>>If I need merely a complex number at run time option to compile a compact routine,
>>any details from any examples of libraries ?
>>Thanks in anticipation.
>>Abdul,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120416/05798a7f/attachment.htm>
