[petsc-users] petsc binary matrix file for dense matrices
Umut Tabak u.tabak at tudelft.nl
Tue Apr 10 07:34:56 CDT 2012
On 04/10/2012 01:55 PM, Jed Brown wrote:
> On Tue, Apr 10, 2012 at 04:27, Umut Tabak <u.tabak at tudelft.nl
> <mailto:u.tabak at tudelft.nl>> wrote:
>     I first had a look at the MATLAB routines to read and write the
>     matrices as examples and MatLoad function manual. I got the idea
>     however I have a question regarding the write operation for dense
>     matrices, in MATLAB code, it is given as
>        [m,n] = size(A);
>        write(fd,[1211214,m*n],'int32');
>        write(fd,A,'double');
> I suggest just using
Dear Jed,
I looked at the MATLAB codes as an example, I should interface my
matrices which are in the C++ code(they are MTL4 compressed or dense
matrices), so they are not in MATLAB.
However, I guess I should use the format given on MatLoad page whether
the matrices are sparse or dense.
I wrote a simple test case which writes the matrix in binary format,
which in this case a sparse matrix, now I guess I can use the same
routine to write a dense matrix as far as I could understand from
MatLoad(There is no separate specification for a dense matrix, right?).
Best,
U.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120410/7d65aa19/attachment-0001.htm>
