[petsc-users] Strange error(?) message
Mohammad Mirzadeh mirzadeh at gmail.com
Mon Apr 9 22:37:26 CDT 2012
Thanks Sean. I'm using Petsc 3.2-p6 along with ParMetis 4.0.2. Since this
was not supported with 3.2-p6, and previous versions had bugs, I built
parmetis myself and used --with-parmetis-include and --with-parmetis-lib
flags to build petsc.
Should I switch to petsc-dev?
On Mon, Apr 9, 2012 at 8:27 PM, Sean Farley <sean at mcs.anl.gov> wrote:
> -on_error_attach_debugger does not start the debugger. I traced it upto
>> the following call:  MatPartitioningApply(). It runs fine up until that
>> function call and then gives the error.
>> Also, to make things even look more weird, I got the following once I was
>> running it:
>> Key 10176 not found!
>> INTERNAL ERROR: Invalid error class (66) encountered while returning from
>> PMPI_Waitall.  Please file a bug report.
>> Do you happen to know what that could mean? The funny thing is, it only
>> happened once!
> This is a parmetis error from libparmetis/util.c:78 and not with petsc
> (well, at least, not directly an error from petsc). How did you build
> parmetis? Which parmetis version and which petsc version are you running?
> You'll probably have to send configure.log to petsc-maint at mcs.anl.gov.
> By the way, the relevant function that is having the error is:
> * This function does a binary search on an array for a key and returns
> * the index
> idx_t BSearch(idx_t n, idx_t *array, idx_t key)
> ... which doesn't help much unless you can step into the debugger and set
> a breakpoint here to give a traceback.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120409/1886d7af/attachment.htm>
