[petsc-users] Coarsening vectors
Mohamad M. Nasr-Azadani mmnasr at gmail.com
Fri Apr 6 18:09:10 CDT 2012
Thanks Jed. Makes sense.
For simple copying values, is there anyway around it so we don't create the
matrix?
Mohamad
On Fri, Apr 6, 2012 at 3:59 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Apr 6, 2012 at 17:56, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
>> I just noticed the command DMCoarsen().
>> I was wondering if there is a simple command which copies the values of
>> the (global) vector created via the fine DM into the coarse DM?
> with petsc-dev or petsc-3.2 respectively,
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMCreateInterpolation.html
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMGetInterpolation.html
> then
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatRestrict.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120406/90553388/attachment.htm>
