[petsc-users] MKL BLAS interface inconsistency
Thu Apr 5 08:53:44 CDT 2012
On Thu, Apr 5, 2012 at 8:05 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Matt,
>    It doesn't look like that link line is even linking against the MKL
> libraries?
Dang, this is a bug with specifying --with-blas-lapack-lib, since it all
gets dumped in
self.lapackLib, then self.blasLib is empty. Pushed a fix to BuildSystem.
Testing now.
   Matt
>   Barry
> On Apr 5, 2012, at 7:54 AM, Alexander Grayver wrote:
> > On 05.04.2012 14:42, Matthew Knepley wrote:
> >> On Thu, Apr 5, 2012 at 7:22 AM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
> >> On 05.04.2012 14:13, Jed Brown wrote:
> >>> On Thu, Apr 5, 2012 at 04:54, Alexander Grayver <
> >>> The inconsistency is still there. I pulled petsc-dev today and came
> across with the same problem:
> >>> src/vec/vec/impls/seq/bvec2.c
> >>> 239:    *z = PetscRealPart(BLASdot_(&bn,xx,&one,xx,&one));
> >>> 240:    *z = PetscSqrtReal(*z);
> >>> This doesn't work with Intel MKL. However in one of the mailing list
> discussions it was said there is now check for that.
> >>> This check didn't work for me apparently. Any ideas why?
> >>> As always, we need configure.log.
> >> Please find it attached.
> >> Please ALWAYS ALWAYS ALWAYS send configure.log to
> petsc-maint at mcs.anl.gov. They are too
> >> big for the public list.
> > Sorry, next time I will.
> >> Second, your problem is that we get a link error tying to test this so
> it looks like
> >> your BLAS have no complex implementations:
> > It does have zdotc. Old petsc-dev works with it fine (after I patched
> vec implementaton myself to get around this issue).
> > home> nm /opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_intel_lp64.a
> | grep zdotc
> > cblas_zdotci_lp64.o:
> > 0000000000000000 T cblas_zdotci_sub
> > cblas_zdotc_lp64.o:
> > 0000000000000000 T cblas_zdotc_sub
> >                  U zdotc
> > _zdotci_lp64.o:
> >                  U mkl_blas_zdotci
> > 0000000000000000 T zdotci
> > 0000000000000000 T zdotci_
> > _zdotc_lp64.o:
> >                  U mkl_blas_zdotc
> > 0000000000000000 T zdotc_
> > home>
> >> sh: /opt/mpi/intel/openmpi-1.4.2/bin/mpicc  -o
> /tmp/petsc-8AEO1f/config.packages.BlasLapack/conftest    -wd1572
> -Qoption,cpp,--extended_float_type -g
> /tmp/petsc-8AEO1f/config.packages.BlasLapack/conftest.o  -ldl
> -L/opt/mpi/intel/openmpi-1.4.2/lib -lmpi -lopen-rte -lopen-pal -lnsl -lutil
> -L/opt/intel/Compiler/11.1/072/ipp/em64t/lib
> -L/opt/intel/Compiler/11.1/072/mkl/interfaces/fftw3xf
> -L//opt/intel/Compiler/11.1/072/lib/intel64
> -L/usr/lib64/gcc/x86_64-suse-linux/4.3
> -L/usr/x86_64-suse-linux/lib -limf -lsvml -lipgo -ldecimal -lgcc_s -lirc
> -lpthread -lirc_s -L/opt/mpi/intel/openmpi-1.4.2/lib
> -L/usr/x86_64-suse-linux/lib -ldl
> >> Executing: /opt/mpi/intel/openmpi-1.4.2/bin/mpicc  -o
> >> sh:
> >> Possible ERROR while running linker:
> /tmp/petsc-8AEO1f/config.packages.BlasLapack/conftest.o: In function `main':
> >> /tmp/petsc-8AEO1f/config.packages.BlasLapack/conftest.c:14: undefined
> reference to `zdotc_'
> >>  output: ret = 256
> >> error message =
> {/tmp/petsc-8AEO1f/config.packages.BlasLapack/conftest.o: In function
> `main':
> >>     Matt
> >> In include/petscblaslapack_uscore.h (and other places), you will find
> the following. So we need to know why PETSC_COMPLEX_DOT_RESULT_ARGUMENT was
> not found by configure.
> >> This I can see...
> >>> #ifdef PETSC_COMPLEX_DOT_RESULT_ARGUMENT
> >>> EXTERN_C_BEGIN
> >>> extern void zdotc_(PetscScalar *,const PetscBLASInt*,const
> PetscScalar*,const PetscBLASInt*,const PetscScalar*,const PetscBLASInt*);
> >>> PETSC_STATIC_INLINE PetscScalar BLASdot_(const PetscBLASInt *n,const
> PetscScalar *x,const PetscBLASInt *sx,const PetscScalar *y,const
> PetscBLASInt *sy) {
> >>>   PetscScalar tmpz;
> >>>   zdotc_(&tmpz,n,x,sx,y,sy);
> >>>   return tmpz;
> >>> EXTERN_C_END
> >>> #else
> >>> #  define BLASdot_     zdotc_
> >>> #endif
> >> Regards,
> >> Alexander
> >> What most experimenters take for granted before they begin their
> experiments lead.
> >> -- Norbert Wiener
> > Regards,
> > Alexander
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120405/1e37afbe/attachment-0001.htm>
