[petsc-users] Questions about PCMG
Mark F. Adams mark.adams at columbia.edu
Tue Apr 3 15:18:46 CDT 2012
On Apr 3, 2012, at 3:25 PM, Yuqi Wu wrote:
> Dear All,
> I want to create two grid preconditioner for the linear Jacobian solve for the nonlinear problem. I am trying to use the inexact Newton as the nonlinear solver, and the fGMRES as the linear solve. For the preconditioner for the linear solve, I want to create a two level ASM preconditioner by using PCMG.
> I use the additive Schwarz (ASM) preconditioned Richardson iteration as the smoother on the fine grid. And use the ASM preconditioned GMRES as the coarse solve.
> But I have the follow questions in setting up the preconditioer,
> 1. When I use the command PCMGGetSmoother to setup the fine grid smoother, it only effective on the down solver but not the up solver.
This should work.  I see that you have PCMGSetNumberSmoothUp in the code below.  By calling an up/down method I think PETSc will decouple the two smoothers, that is make a copy of the smoother and use one for up and one for down.  So you want to avoid and U//Down methods or command line parameters.
> Although I want to use same smoother for up and down procedure, I need to call PCMGGetSmootherUp and PCMGGetSmootherDown to setup the smoother seperately. Do you have any ideas about this issue?
> 2. In my two level preconditioner, I need three ASM preconditioner, two for the up and down smoother, and one for the coarse solve. If I want to use LU factorization as the subdomain solve for both the up and down smoother, but I don't want to redo the LU factorization for the up smoother. How can I keep the LU factorization for the down smoother in order to use for the up smoother?
> 3. I run my code with the my twolevel preconditioner. The SNES converges in two iteration.
>  0 SNES norm 1.014991e+02, 0 KSP its (nan coarse its average), last norm 0.000000e+00.
>  1 SNES norm 9.925218e-05, 4 KSP its (5.25 coarse its average), last norm 2.268574e-06.
>  2 SNES norm 1.397282e-09, 5 KSP its (5.20 coarse its average), last norm 1.312605e-12.
> In the log summary, I check the number of the factorization in the problem
> MatLUFactorSym         4 1.0 1.1232e+00 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+01  2  0  0  0  1   2  0  0  0  1     0
> MatLUFactorNum         4 1.0 1.3245e+01 2.2 1.22e+09 3.0 0.0e+00 0.0e+00 0.0e+00 28 86  0  0  0  30 86  0  0  0   553
> Do you have any ideas that why the number of MatLUFactorSym is 4? And is there any approach that I can find out how much LU factorization are done for the coarse solve, and how much LU factorization are done for the up and down smoother?
-pc_mg_log will give some level information but I'm not sure if it does setup stuff.
Running with -info gives verbose output (I would run with one processor) and you can see the sizes of the factorizations, along with fill stats, etc.
> I believe the number should be six, in each SNES iteration, I have need to do two LU for the up and down smoother, and one LU for the coarse solve. Because we have two SNES iteration now, the number of LU factorization should be 6 instead of 4.
> Thank you so much for your help. Below is the output form the SNESView of my program, and the setup of my preconditioner.
> Best
> Yuqi Wu
> /* SNES view */
> SNES Object: 8 MPI processes
>  type: ls
>    line search variant: SNESLineSearchCubic
>    alpha=1.000000000000e-04, maxstep=1.000000000000e+08, minlambda=1.000000000000e-12
>  maximum iterations=10, maximum function evaluations=10000
>  tolerances: relative=1e-07, absolute=1e-50, solution=1e-08
>  total number of linear solver iterations=9
>  total number of function evaluations=3
>  KSP Object:   8 MPI processes
>    type: fgmres
>      GMRES: restart=100, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>      GMRES: happy breakdown tolerance 1e-30
>    maximum iterations=1000, initial guess is zero
>    tolerances:  relative=1e-06, absolute=1e-14, divergence=10000
>    right preconditioning
>    using UNPRECONDITIONED norm type for convergence test
>  PC Object:   8 MPI processes
>    type: mg
>      MG: type is MULTIPLICATIVE, levels=2 cycles=v
>        Cycles per PCApply=1
>        Using Galerkin computed coarse grid matrices
>    Coarse grid solver -- level -------------------------------
>      KSP Object:      (coarse_)       8 MPI processes
>        type: gmres
>        tolerances:  relative=0.001, absolute=1e-50, divergence=10000
>      PC Object:      (coarse_)       8 MPI processes
>        type: asm
>          Additive Schwarz: total subdomain blocks = 8, user-defined overlap
>          Additive Schwarz: restriction/interpolation type - RESTRICT
>          Local solve is same for all blocks, in the following KSP and PC objects:
>        KSP Object:        (coarse_sub_)         1 MPI processes
>          type: preonly
>          maximum iterations=10000, initial guess is zero
>          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>          left preconditioning
>          using NONE norm type for convergence test
>        PC Object:        (coarse_sub_)         1 MPI processes
>          type: lu
>            LU: out-of-place factorization
>            tolerance for zero pivot 1e-12
>            matrix ordering: nd
>            factor fill ratio given 5, needed 3.73447
>              Factored matrix follows:
>                Matrix Object:                 1 MPI processes
>                  type: seqaij
>                  rows=840, cols=840
>                  package used to perform factorization: petsc
>                  total: nonzeros=384486, allocated nonzeros=384486
>                  total number of mallocs used during MatSetValues calls =0
>                    using I-node routines: found 349 nodes, limit used is 5
>          linear system matrix = precond matrix:
>            type: seqaij
>            rows=840, cols=840
>            total: nonzeros=102956, allocated nonzeros=102956
>              using I-node routines: found 360 nodes, limit used is 5
>        Matrix Object:         8 MPI processes
>          type: mpiaij
>          rows=4186, cols=4186
>          total: nonzeros=656174, allocated nonzeros=656174
>            using I-node (on process 0) routines: found 315 nodes, limit used is 5
>    Down solver (pre-smoother) on level 1 -------------------------------
>      KSP Object:      (mg_levels_1_)       8 MPI processes
>        type: richardson
>          Richardson: damping factor=1
>        maximum iterations=1, initial guess is zero
>        using PRECONDITIONED norm type for convergence test
>      PC Object:      (fine_)       8 MPI processes
>        type: asm
>        KSP Object:        (fine_sub_)         1 MPI processes
>          type: preonly
>        PC Object:        (fine_sub_)         1 MPI processes
>          type: lu
>            matrix ordering: nd
>            factor fill ratio given 5, needed 5.49559
>                  type: seqaij
>                  rows=2100, cols=2100
>                  total: nonzeros=401008, allocated nonzeros=401008
>                    using I-node routines: found 1491 nodes, limit used is 5
>            type: seqaij
>            total: nonzeros=72969, allocated nonzeros=72969
>              using I-node routines: found 1532 nodes, limit used is 5
>          type: mpiaij
>          rows=11585, cols=11585
>          total: nonzeros=458097, allocated nonzeros=3026770
>          total number of mallocs used during MatSetValues calls =978
>            using I-node (on process 0) routines: found 1365 nodes, limit used is 5
>    Up solver (post-smoother) on level 1 -------------------------------
>        type: richardson
>        using nonzero initial guess
>        type: asm
>          type: preonly
>          type: lu
>            matrix ordering: nd
>                  type: seqaij
>            type: seqaij
>          type: mpiaij
>      type: mpiaij
> SNES converged: CONVERGED_FNORM_RELATIVE.
> Below setup of my preconditioner,
>  /* set up the MG preconditioner */
>  ierr = SNESGetKSP(snes,&fineksp);CHKERRQ(ierr);
>  ierr = KSPGetPC(fineksp,&finepc);CHKERRQ(ierr);
>  ierr = PCSetType(finepc,PCMG);CHKERRQ(ierr);
>  ierr = PCMGSetType(finepc,PC_MG_MULTIPLICATIVE);CHKERRQ(ierr);
>  ierr = PCMGSetLevels(finepc,2,PETSC_NULL);CHKERRQ(ierr);
>  ierr = PCMGSetCycleType(finepc,PC_MG_CYCLE_V);CHKERRQ(ierr);
>  ierr = PCMGSetNumberSmoothUp(finepc,1);CHKERRQ(ierr);
>  ierr = PCMGSetNumberSmoothDown(finepc,1);CHKERRQ(ierr);
>  ierr = PCMGSetGalerkin(finepc,PETSC_TRUE);CHKERRQ(ierr);
>  ierr = PCMGSetResidual(finepc,1,PCMGDefaultResidual,algebra->J);CHKERRQ(ierr);
>  ierr = PCMGSetInterpolation(finepc,1,ctx->Interp);CHKERRQ(ierr);
>  /* set up the coarse solve */
>  ierr = PCMGGetCoarseSolve(finepc,&ctx->coarseksp);CHKERRQ(ierr);
>  ierr = KSPSetOptionsPrefix(ctx->coarseksp,"coarse_");CHKERRQ(ierr);
>  ierr = KSPSetFromOptions(ctx->coarseksp);CHKERRQ(ierr);
>  /* set up the fine grid smoother */
>  ierr = PCMGGetSmoother(finepc,1,&kspsmooth);CHKERRQ(ierr);
>  ierr = KSPSetType(kspsmooth, KSPRICHARDSON);CHKERRQ(ierr);
>  ierr = KSPGetPC(kspsmooth,&asmpc);CHKERRQ(ierr);
>  ierr = PCSetType(asmpc,PCASM);CHKERRQ(ierr);
>  ierr = PCASMSetOverlap(asmpc,0);CHKERRQ(ierr);
>  ierr = PCASMSetLocalSubdomains(asmpc,1,&grid->df_global_asm,PETSC_NULL);CHKERRQ(ierr);
