[petsc-users] VecSetValues
khalid ashraf khalid_eee at yahoo.com
Tue Apr 3 03:46:13 CDT 2012
Hi Matt, I ran the program on two processors. I am trying to enter value into a
vector associated with DA. I am using VecSetValues since I may need to assign nonlocal
values to the vector. However, I find that on 2 procs, a general parallel vector works but
the DAVector indexing is not working. Do you see any problem with the DA code ?
Thanks.
Khalid
THIS WORKS: 30 is written at index 5
ppy=5; ppx=30;
VecCreate(PETSC_COMM_WORLD,&testVec);
VecSetFromOptions(testVec);
VecSetSizes(testVec,PETSC_DECIDE,384);
VecSetValues(testVec,1,&ppy,&ppx,INSERT_VALUES);
VecAssemblyBegin(testVec);
VecAssemblyEnd(testVec);
THIS DOES NOT WORK: puts 30 at index 9 instead of 5 when run on two procs.
ppy=5; ppx=30;
ierr = DACreate3d(PETSC_COMM_WORLD,DA_YPERIODIC,DA_STENCIL_BOX,8,8,6,
                    PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,PETSC_NULL,PETSC_NULL,PETSC_NULL,
                    &appctx.da);CHKERRQ(ierr);
 ierr = DACreateGlobalVector(da,&testVec);CHKERRQ(ierr)
To: khalid ashraf <khalid_eee at yahoo.com>
Cc: PETSc users list <petsc-users at mcs.anl.gov>
Sent: Monday, April 2, 2012 3:08 PM
Subject: Re: [petsc-users] transfer vector data diagonally on DA
On Mon, Apr 2, 2012 at 4:53 PM, khalid ashraf <khalid_eee at yahoo.com> wrote:
Thanks Matt. It works now.
>I have another problem. I am writing this program.
1) Always test on 2 procs once
2) I have no idea what you actually want to do. However, it really simple to just print out
    the indices you are using in row[] and the values in bodyFx[] and check that VecSetValues()
    is working as you expect.
   Matt
> for (k=zs; k<zs+zm; k++) {
>  for (j=ys; j<ys+ym; j++) {
>  for (i=xs; i<xs+xm; i++) {
> if ( i!=(mx-1) || j!=my-1 || k!=mz-1)
>bodyFx[0]=1;
>bodyFx[1]=-0.3;
>bodyFx[2]=-0.3;
>bodyFx[3]=-0.3;
>row[0]=k*mx*my+j*mx+i;
>row[1]=k*mx*my+j*mx+i+1;
>row[2]=k*mx*my+(j+1)*mx+i;
>row[3]=(k+1)*mx*my+j*mx+i;
>VecSetValues(fx_test,4,row,bodyFx,ADD_VALUES);
>VecAssemblyBegin(fx_test);
>VecAssemblyEnd(fx_test);
>Output: Print fx_test
> Here fx_test is a global vector. This program gives correct output on 1 proc. but on 4 processors,
>the program runs but the outputs are wrong.
>I also tried
>bodyFx[0]=1;
>bodyFx[1]=-0.3;
>bodyFx[2]=-0.3;
>bodyFx[3]=-0.3;
> fx1_localptr[k][j][i+1]+=bodyFx[4];
> fx1_localptr[k][j+1][i]+=bodyFx[3];
> fx1_localptr[k+1][j][i]+=bodyFx[1];
> fx1_localptr[k][j][i]+=bodyFx[0];
>Here, fx1_localptr is an array from a local vector that is communicated from the global vector fx_test.
>In this case as well, I get similar errors.
>Thanks.
>Khalid
>Some final numbers of the vector with 8*8*6 grid, 4 proc,
>-2.9999999999999999e-01
>1.0000000000000009e-01
>0.0000000000000000e+00
>4.0000000000000002e-01
>Some final numbers of the vector with 8*8*6 grid, 1 proc,
>________________________________
> From: Matthew Knepley <knepley at gmail.com>
>To: khalid ashraf <khalid_eee at yahoo.com>; PETSc users list <petsc-users at mcs.anl.gov>
>Sent: Monday, April 2, 2012 5:41 AM
>On Mon, Apr 2, 2012 at 3:36 AM, khalid ashraf <khalid_eee at yahoo.com> wrote:
>Hi Jed,
>>I am using petsc/3.1 and the include file "petscdmda.h" is not working. I am using the "petscda.h"
>>and DACreate3D.
>>unew_localptr[][][] is from a global vector using VecGetArray
>>u_localptr[][][] is from a local vector communicated from a global vector.
>>I tried
>>unew_localptr[k][j][i]=u_localptr[k-1][j-1][i-1]
>>but it gives Segmentation Violation error.
>I would guess (because you provide almost no information about what you are doing), that
>this is a domain on the edge. If you truly mean to have a periodic domain, you must set that in the
>creation call. Then the local vector will also ghost regions outside the domain boundary.
>   Matt
>I also tried unew_localptr[k][j][i]=u_localptr[k][j+1][i+1] which works but
>>unew_localptr[k][j][i]=u_localptr[k+1][j+1][i+1] or unew_localptr[k][j][i]=u_localptr[k][j-1][i-1]
>>does not work. I am running the program on4 processors.
>>Thanks.
>>  ierr = DACreate3d(PETSC_COMM_WORLD,DA_YPERIODIC,DA_STENCIL_BOX,appctx.l,appctx.m,appctx.n,
>>  if(i!=0 || j!=0 || k!=0|| i!=mx-1 || j!=my-1 || k!=mz-1)
>>  unew_localptr[k][j][i]=u_localptr[k+1][j+1][i+1];
>>From: Jed Brown <jedbrown at mcs.anl.gov>
>>Sent: Sunday, April 1, 2012 10:07 PM
>>On Sun, Apr 1, 2012 at 22:01, khalid ashraf <khalid_eee at yahoo.com> wrote:
>>I want to transfer vector data diagonally in the DA grid like
>>>if(i!=mx-1 || j!=my-1 || k!=mz-1){
>>>u_new[k+1][j+1][i+1]=u[k][j][i];}
>>>Could you please suggest the best way to do it minimizing interprocessor assignments.
>>Both are on the same DMDA?
>>Communicate U to Ulocal (DMGlobalToLocalBegin/End) using a BOX stencil with width at least 1, get the global array u_new[][][] from UGlobalNew and the local arrays u[][][] from Ulocal, then assign u_new[k][j][i] = u[k-1][j-1][i-1].
>What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120403/5a8cceba/attachment-0001.htm>
