[petsc-users] DAGetMatrix with extra nonzeros: memory preallocation
Mohamad M. Nasr-Azadani mmnasr at gmail.com
Sun Sep 11 05:44:20 CDT 2011
Thanks Jed,
I will give it a shot. I think I will need your help though, it sounds a
tedious task to digg into low-level PETSc codes. :-)
Best,
Mohamad
On Sat, Sep 10, 2011 at 2:15 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Sep 10, 2011 at 23:03, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
>> Is there any example that could guide me on that?
> Unfortunately there is not. You can read the man page for
> MatMPIAIJSetPreallocation() and look at the implementations in DMDA that use
> this API (e.g. DMGetMatrix_DA_2d_MPIAIJ in src/dm/impls/da/fdda.c -- your
> implementation should be somewhat simpler because you only need one stencil
> in the interior).
> It would be good to have an example of preallocating for something
> nontrivial, so if you write one, we can add it (and help debug if you get
> stuck).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110911/fdc1c31b/attachment.htm>
