[petsc-users] PETSc 3.2 release candidate
Sat Sep 3 13:03:49 CDT 2011
You can try FCPPFLAGS instead of PETSC_INCLUDE
Also - suggest renaming all sources [that call PESc] to .F90 - and
simplify makefile. [as PETSc targets compile .F90 files properly.]
Satish
On Sat, 3 Sep 2011, Tabrez Ali wrote:
> Hello
> What is the equivalent of $(PETSC_INCLUDE) in petsc-3.2? I am using Fortran
> and my files end in .f90. My working Makefile for petsc-3.1 (with gfortran)
> looks like
> include ${PETSC_DIR}/conf/variables
> include ${PETSC_DIR}/conf/rules
> all:
>         mpif90 -c -Wall -x f95-cpp-input $(PETSC_INCLUDE) a.f90 b.f90 c.f90
>         $(FLINKER) a.o b.o c.o $(PETSC_FORTRAN_LIB) $(PETSC_LIB) -o exec
>         $(RM) *.o *.mod
> With 3.2 I get the error
> stali at i5:~/src$ make all
> mpif90 -c -Wall -x f95-cpp-input a.f90 b.f90 c.f90
> b.f90:8:0: fatal error: finclude/petscsys.h: No such file or directory
> Thanks in advance
> Tabrez
> On 09/02/2011 09:01 PM, Satish Balay wrote:
> > Also one can use the following tarball. It will correspond to
> > petsc-3.2 sources for the next few days. And i've set it up to be
> > updated every 3 hours [from the sources in mercurial].
> > http://ftp.mcs.anl.gov/pub/petsc/petsc-dev.tar.gz
> > Satish
> > On Fri, 2 Sep 2011, Barry Smith wrote:
> > >     You can find the PETSc 3.2 release candidate via Mecurial at:
> > > > ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2
> > > > or    http://petsc.cs.iit.edu/petsc/releases/petsc-3.2
> > > > ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/BuildSystem-3.2
> > > > or    http://petsc.cs.iit.edu/petsc/releases/BuildSystem-3.2
> > >     If you find any problems please let us know.  We'll be making the
> > > tarball in a couple of days.
> > >     Thanks
> > >      Barry
> > >     If you fix anything, please make the fix in petsc-3.2 not petsc-dev
