[petsc-users] Block ILU with AIJ matrix?
Gong Ding gdiso at ustc.edu
Mon Oct 31 00:50:28 CDT 2011
I had also considered use max block size. But it is not efficient here.
Hope petsc support nonuniform block size one day.
I think you may choose the maximum block size as a BAIJ dimension. However ITSOL has variable BLOCK ILU routine which may help you BUT it is not paralleled.
http://www-users.cs.umn.edu/~saad/software/ITSOL/index.html
B.B.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111031/f7a9ba69/attachment.htm>
