[petsc-users] KSP with MatNullSpace
Wed Nov 23 17:00:17 CST 2011
On Nov 23, 2011, at 1:31 PM, Shiyuan wrote:
> I've check it in Matlab. the matrix A is symmetric and has no negative eigenvalues( only a zero eigen value). I've also checked that the nullspace is correct(  norm(A*phi)<1e-11);
   Hmm. You can run with -ksp_view_binary and email to petsc-maint at mcs.anl.gov the resulting file called binaryoutput.
   Barry
> Thanks.
> On Wed, Nov 23, 2011 at 1:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Print out the matrix for a small grid then check in Matlab that it is symmetric and has no negative eigenvalues.
>   Barry
> On Nov 23, 2011, at 9:50 AM, Shiyuan wrote:
> > Hi,
> >     I want to solve a singular system with a known nullspace. However, I the KSP solve diverges with KSP_INDEFINTE_PC even if I disable the preconditioning by PCNONE.
> > this is how I setup the system. What did I do wrong? Any possible causes? Thanks.
> >    ierr=MatNullSpaceCreate(PETSC_COMM_SELF,PETSC_FALSE,1,&phi,&nsp);CHKERRV(ierr);
> >   ierr=KSPCreate(PETSC_COMM_SELF,&ksp);CHKERRV(ierr);
> >   ierr=KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);CHKERRV(ierr);
> >   ierr=KSPSetNullSpace(ksp,nsp);CHKERRV(ierr);
> >   ierr=KSPSetType(ksp,KSPCG);CHKERRV(ierr);
> >   ierr=KSPGetPC(ksp,&prec);CHKERRV(ierr);
> >   ierr=PCSetType(prec,PCNONE);CHKERRV(ierr);
> >   ierr=KSPSetTolerances(ksp,1e-5,1e-20,1e5,10000);CHKERRV(ierr);
> >   ierr=KSPSetFromOptions(ksp);CHKERRV(ierr);
> >   ierr=KSPSetUp(ksp);CHKERRV(ierr);
> > Shiyuan
