[petsc-users] Assembling primal Schur matrix in FETI-DP method
Fri Nov 18 12:42:15 CST 2011
On Fri, Nov 18, 2011 at 07:53, Thomas Witkowski <
Thomas.Witkowski at tu-dresden.de> wrote:
> Defining the sparsity pattern is no problem. But is there any
> documentation on MatFDColoringApply? The online function reference is quite
> short and is not mentioned in the manuel. So, I have no real idea how this
> is related to my question.
You can find an example in snes/examples/tutorials/ex15.c
The point is that it can compute the Schur complement by coloring. In your
case, you can do subdomain solves independently, so you can compute
S = K_PiPi - K_PiB inv(K_BB) K_BPi
on each subdomain using
Tmp = inv(K_BB) K_BPi      (via MatMatSolve)
Tmp2 = K_PiB * Tmp     (via MatMatMult)
S = K_PiPi - Tmp2    (via MatAXPY)
You would then assemble the resulting independent matrices into the global
matrix.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111118/381afe1f/attachment.htm>
