[petsc-users] RK substeps
Fri Nov 11 09:55:32 CST 2011
On Fri, Nov 11, 2011 at 3:52 PM, Juha Jäykkä <juhaj at iki.fi> wrote:
> > What exactly are you using TAO to do?
> I have a large scale minimisation problem related to the problem I am using
> PETSc to solve. The PETSc code is independent, so I could have two PETSc's
> around and use the older one for TAO, but that seems like a lot of hassle
> without significant benefit.
> I know the SNES module could be used as a substitute for TAO. At the
> moment, I
> solve min(\int f(x)), where TAO needs the gradients of f(x); I could also
> solve discrete grad(f(x))=0 with SNES, but as I then need compute the
> Jacobian
> (=Hessian of f(x)), too, this has seemed to be too memory intensive to be
> useful. I am not aware of a way around this.
There are plenty of ways to use SNES without a Mat. You can use -snes_mf,
which
uses a FD approximation to the action of the matrix. You can use -snes_type
qn
which uses a quasi-Newton approximation, or even -snes_type nrichardson,
which
just uses successive substitutions with your residual function.
      Matt
> -Juha
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111111/17d02567/attachment-0001.htm>
