[petsc-users] RK substeps
Fri Nov 11 09:01:26 CST 2011
On Fri, Nov 11, 2011 at 2:58 PM, Juha Jäykkä <juhaj at iki.fi> wrote:
> > We pass in the time of the stage when your RHSFunction is called. If you
> Right, how can I have missed that?!? Thanks.
> > haven't eliminated boundary conditions, your system is likely
> > differential-algebraic, in which case you can use the IFunction interface
> Eliminated? I am not sure what you mean. My boundaries are "periodic", but
> thanks to the nature of my problem, they are periodic only up to a gauge
> transformation. I need to perform that gauge transform at each time step.
> I would be more than happy not to have to do that, but I cannot really see
> a
> way out of it, so, if you have any ideas, I am very interested in hearing
> them.
> > improved in petsc-dev, so consider using it if you want the latest
> Thanks for the tip, but I am stuck at 3.1 because I need TAO, too and it
> still
> does not support 3.2.
What exactly are you using TAO to do?
     Matt
> Cheers,
> Juha
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111111/037003b4/attachment.htm>
