[petsc-users] Solution update is not working in TS
Konstantinos Kontzialis ckontzialis at lycos.com
Mon Nov 7 12:55:55 CST 2011
On 11/07/2011 04:50 PM, petsc-users-request at mcs.anl.gov wrote:
> Send petsc-users mailing list submissions to
> 	petsc-users at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	petsc-users-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-users digest..."
> Today's Topics:
>     1.  Extremal Singular Values (behzad baghapour)
>     2. Re:  about Singular value (Matthew Knepley)
>     3.  Solution update is not working in TS (Konstantinos Kontzialis)
>     4. Re:  TS solution (Jed Brown)
>     5. Re:  Solution update is not working in TS (Jed Brown)
>     6. Re:  Petsc-3.2 with superlu_dist building error (Ping Rong)
>     7. Re:  Petsc-3.2 with superlu_dist building error (Jed Brown)
> Message: 1
> Date: Mon, 7 Nov 2011 16:05:58 +0330
> From: behzad baghapour<behzad.baghapour at gmail.com>
> Subject: [petsc-users] Extremal Singular Values
> To: PETSc users list<petsc-users at mcs.anl.gov>
> Message-ID:
> 	<CA+jOtDKkftQb=A1dx6quevgGN0HT8uw5-sKL6h5+BbALRg5SDg at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Is there any link with "Incremental Condition Estimation" (ICE) developed
> by Bischof in LAPACK with Petsc to evaluate Extremal singular values?
> Thanks, Behzad.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:<http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111107/dc4064bc/attachment-0001.htm>
> Message: 2
> Date: Mon, 7 Nov 2011 13:16:43 +0000
> From: Matthew Knepley<knepley at gmail.com>
> Subject: Re: [petsc-users] about Singular value
> Message-ID:
> 	<CAMYG4GmRhn3jeAmv3sGw4kGfQbf=2KyX1xG0nK51g+NoLZf7Vg at mail.gmail.com>
> On Mon, Nov 7, 2011 at 9:06 AM, behzad baghapour<behzad.baghapour at gmail.com
> We do not use this (it is intended for triangular matrices). It may be
> tenuously connected. He says he is
> approximating the secular equation with rational functions, in some sense
> we are approximating the
> characteristic equation with polynomials (Krylov).
>      Matt
>> Thanks,
>> B.B.
>> On Sun, Oct 30, 2011 at 6:49 PM, Jed Brown<jedbrown at mcs.anl.gov>  wrote:
>>> On Sun, Oct 30, 2011 at 05:17, Matthew Knepley<knepley at gmail.com>  wrote:
>>>> We call LAPACK SVD on the Hermitian matrix made by the Krylov method.
>>> GMRES builds a Hessenberg matrix.
Dear Jed,
I perform a simulation over a cylinder at M=0.14 using the Euler
equations. The explicit part now works . I use the Vec vector in my
monitor routine and I get the results.
But,  when I go for the implicit solution I code:
ierr = TSCreate(sys.comm, &sys.ts);
     CHKERRQ(ierr);
     ierr = TSSetProblemType(sys.ts, TS_NONLINEAR);
     CHKERRQ(ierr);
     ierr = TSSetSolution(sys.ts, sys.gsv);
     CHKERRQ(ierr);
     ierr = TSSetIFunction(sys.ts, PETSC_NULL, base_residual_implicit,
&sys);
     CHKERRQ(ierr);
     ierr = TSGetSNES(sys.ts, &sys.snes);
     CHKERRQ(ierr);
     ierr = MatCreateSNESMF(sys.snes, &sys.J);
     CHKERRQ(ierr);
     ISColoring iscoloring;
     MatFDColoring matfdcoloring;
     ierr = jacobian_diff_numerical(sys, &sys.P);
     CHKERRQ(ierr);
     ierr = MatGetColoring(sys.P, MATCOLORINGSL, &iscoloring);
     CHKERRQ(ierr);
     ierr = MatFDColoringCreate(sys.P, iscoloring, &matfdcoloring);
     CHKERRQ(ierr);
     ierr = MatFDColoringSetFunction(matfdcoloring,
             (PetscErrorCode(*)(void)) SNESTSFormFunction, sys.ts);
     CHKERRQ(ierr);
     ierr = MatFDColoringSetFromOptions(matfdcoloring);
     CHKERRQ(ierr);
     ierr = ISColoringDestroy(&iscoloring);
     CHKERRQ(ierr);
     ierr = SNESSetJacobian(sys.snes, sys.J, sys.P,
             SNESDefaultComputeJacobianColor, matfdcoloring);
     CHKERRQ(ierr);
     ierr = TSSetInitialTimeStep(sys.ts, sys.con->tm, sys.con->dt);
     CHKERRQ(ierr);
     ierr = TSSetDuration(sys.ts, 100e+6, sys.con->etime);
     CHKERRQ(ierr);
     ierr = TSMonitorSet(sys.ts, monitor, &sys, PETSC_NULL);
     CHKERRQ(ierr);
     ierr = TSSetFromOptions(sys.ts);
     CHKERRQ(ierr);
     ierr = TSSolve(sys.ts, sys.gsv, &sys.con->etime);
     CHKERRQ(ierr);
and I run with:
mpiexec -n 8 valgrind ./hoac cylinder -llf_flux -n_out 500 -end_time
50.0 -dt 2.0e-1 -ts_type beuler -gl -implicit
and I get:
   METIS 4.0.3 Copyright 1998, Regents of the University of Minnesota
Graph Information ---------------------------------------------------
   Name: mesh.graph, #Vertices: 400, #Edges: 780, #Parts: 8
Recursive Partitioning... -------------------------------------------
   8-way Edge-Cut:     102, Balance:  1.00
Timing Information --------------------------------------------------
   I/O:                     0.000
   Partitioning:            0.000   (PMETIS time)
   Total:                   0.000
Approximation order = 1
# DOF = 6080
# nodes in mesh = 400
# elements in mesh = 380
Euler solution
Using LLF flux
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state!
[0]PETSC ERROR: Must call SNESSetFunction() or SNESSetDM() first
