[petsc-users] Insering rows vs inserting columns
Wed May 25 21:25:37 CDT 2011
On Thu, 26 May 2011, Bartłomiej W wrote:
> Hello,
> I have a slight problem with performance of matsetvalues when inserting values row-by-row on single processor instead of column-by-column.
>      ierr = MatCreate(PETSC_COMM_WORLD,&L);
>      ierr = MatSetSizes(L,PETSC_DECIDE,PETSC_DECIDE,n,n);
>      ierr = MatSetFromOptions(L);
>      MatSeqAIJSetPreallocation(L,PETSC_NULL,nnz);
>      MatSetValues(L,rows,indices_y,1,&col,values,INSERT_VALUES);
> vs
>      MatSetValues(L,1,&row,cols,indices_x,values,INSERT_VALUES);
> First way goes quick and gives me mallocs in matsetvalues = 0 in -info
> While the second one takes much longer and does mallocs.
> Why is it so that inserting rows is slower than inserting columns when proper nnz was provided? Or maybe there is my mistake here somewhere?
The order or the way the values are inserted shouldn't matter. As long
as the correct nozero structure is provided [with nnz] - there should
be no additional mallocs.
you can check with MatView() to see if the matrix is anyway different
in the 2 cases.
Satish
> Regards
