[petsc-users] configure mpirun problem
Mon May 23 14:21:09 CDT 2011
On Mon, May 23, 2011 at 2:16 PM, charles reid <charlesreid1 at gmail.com>wrote:
> Hi -
> I'm trying to install Petsc and linking to OpenMPI, but running into a
> conflict with the compiler test.  If I specify my MPI installation directory
> and my mpiexec command, like so:
> ./configure \
>  --prefix=/uufs/
> chpc.utah.edu/common/home/u0552682/pkg/petsc/3.0.0_incendio \
>  --with-x=false \
>  --with-matlab=false \
>  --download-f-blas-lapack=ifneeded \
>  --with-mpi-dir=/uufs/chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3\
>  --with-mpiexec=/uufs/
> chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpirun \
>  --with-blas-lapack-dir=/usr/lib \Checking for program /uufs/
> chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc...found
>           Defined make macro "CC" to "/uufs/
> chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc"
>           Pushing language C
> sh: /uufs/chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc-c -o conftest.o   conftest.c
> Executing: /uufs/
> chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc -c -o
> sh:
> Executing: /uufs/
> sh:
>                                           Pushing language C
>                                           Popping language C
>                                           Pushing language Cxx
>                                           Popping language Cxx
>                                           Pushing language FC
>                                           Popping language FC
>                   Pushing language C                  Popping language C
> -o conftest     conftest.o
> Executing: /uufs/
> chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc  -o
> conftest     conftest.o
> sh:
> Executing: /uufs/
> sh:                      Pushing language C
>                       Popping language C
> Executing: /uufs/
> conftest     conftest.o
> sh:Executing: ./conftest
> sh: ./conftest
> Executing: ./conftestsh:
> ERROR while running executable: Could not execute './conftest':./conftest:
> error while loading shared libraries: libmpi.so.0: cannot open shared object
> file: No such file or directory
>  --with-shared=0 \
> The underlying problem can be demonstrated with a simple C hello world
> program:
> $ cat test.c
> #include <stdio.h>
> main()
>   printf ("Hello World!\n");
> $ /uufs/chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc  -o
> test.o test.c
> $ ./test.o
> ./test.o: error while loading shared libraries: libmpi.so.0: cannot open
> shared object file: No such file or directory
> Running the executable with mpirun alone shows the same error (similar to
> this thread at OpenMPI list:
> http://www.open-mpi.org/community/lists/users/2006/07/1691.php)
> $ mpirun -np 1 ./test.o
> and ultimately the resolution is to specify the full path of mpirun when
> running the executable (as per the response to the above thread,
> http://www.open-mpi.org/community/lists/users/2006/07/1692.php):
> $ `which mpirun` -np 1 ./test.o
> Hello World!
> So my question is, why does Petsc's compiler test insist on running the
> mpicc-built test executable in an incorrect way (i.e. ./conftestsh instead
> of /path/to/mpiexec ./conftest)?  And how can I compile with OpenMPI
> support?  I'm unable to bypass this by specifying CC and CXX, as I just run
> into problems later on with mpi_init not being found.
There are many, many ways to run an executable. We count on 'sh
<executable>' as a default, and if that does not work
 then you can run configure using --with-batch.
    Matt
> Charles
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110523/8c122073/attachment.htm>
