[petsc-users] Direct solver for 3D-FEM
Thomas Witkowski thomas.witkowski at tu-dresden.de
Fri May 20 07:55:19 CDT 2011
Could one of you explain me why direct solvers (I make use of UMFPACK)
seems to work quite bad for 3D-FEM? For a small test case, I take a
unite square/box and refine it globally (bisectioning of
triangle/tetrahedrons). I solve a six order PDE  (that leads to
symmetric but indefinite matrices) on it. In 2D the resulting system has
49.923 rows with 808.199 non zeros, UMFPACK solves the system within 2.8
seconds. For 3D I've refine the box such that the resulting matrix has
more or less the same number of non zeros, in this case 898.807 on
27.027 rows. UMFPACK needs 32 seconds to solve it, so more than 10 time
as for the 2D case. Even if I make use of fourth order Lagrange
functions for the 2D case, which leads to much denser matrices (49.923
rows and 2.705.927 non zeros), UMFPACK solves it within 3.2 seconds. Is
there any good reason for it?
Thomas
