[petsc-users] VecSetValue. fails with -O1/2/3
Clemens Domanig clemens.domanig at uibk.ac.at
Wed May 18 02:15:27 CDT 2011
First ValGrind didn't find anything but then the solution was found in
Valgrind FAQ 4.6 (--tool=exp-ptrcheck)
Thx for the help
Jed Brown wrote:
> Try with valgrind. The compiler is probably initializing a variable only
> at -O0.
>> On May 16, 2011 8:28 AM, "Clemens Domanig" <clemens.domanig at uibk.ac.at
>> <mailto:clemens.domanig at uibk.ac.at>> wrote:
>> Hi everyone,
>> maybe someone can explain to me what is going wrong with my code.
>> In my programm I read values from a vector A and write them at new
>> positions into a vector B. This works well as long as I don't use any
>> optimization-flags when compiling the code. If I use -O1/2/3 the petsc
>> tells me: "out of range error" at VecSetValue.
>> It always happens at the some position although I'm doing this kind of
>> operations at different places again.
>> petsc-version 3.1.6
>> g++-version: gcc version 4.1.2 20080704 (Red Hat 4.1.2-48)
>> Thx for your help - C. Domanig
