[petsc-users] Preallocation (Unstructured FE)
Tue May 17 11:21:05 CDT 2011
On Tue, May 17, 2011 at 9:36 AM, Tabrez Ali <stali at geology.wisc.edu> wrote:
>  Matt
> An example which reads an unstructured mesh (ascii or exodus), partitions
> it and sets up Mat (with the right preallocation) would be great. If it is
> in Fortran then that would be perfect. Btw my problem also has Lagrange
> multiplier constraints.
Yes, I should have been more specific. What element?
     Matt
> Thanks
> Tabrez
> On 05/17/2011 08:25 AM, Matthew Knepley wrote:
> On Mon, May 2, 2011 at 8:16 AM, Tabrez Ali <stali at geology.wisc.edu> wrote:
>>  Is there a way I can use this and other mesh routines from Fortran? The
>> manual doesn't say much on this.
>  Yes, but you are right that nothing is in the manual. DMMESH (in
> petsc-dev) now obeys the full DM interface,
> so that DMGetMatrix() will return you a properly allocated Mat. So what is
> the problem? Of course, it is that
> Petsc has no good way to specify what finite element you are dealing with.
>  The way I was doing this is to encode it using some C++ classes. This
> turns out to be a bad way to do things.
>  I am currently reworking it so that this information is stored in a simple
> C struct that you can produce. Should
> have this done soon.
>  Can you mail me a description of an example you would like to run?
>    Thanks,
>       Matt
>> Tabrez
>> On 05/01/2011 09:53 AM, Matthew Knepley wrote:
>> On Sat, Apr 30, 2011 at 12:58 PM, Tabrez Ali <stali at geology.wisc.edu>wrote:
>>> Petsc Developers/Users
>>> I having some performance issues with preallocation in a fully
>>> unstructured FE code. It would be very helpful if those using FE codes can
>>> comment.
>>> For a problem of size 100K nodes and 600K tet elements (on 1 cpu)
>>> 1. If I calculate the _exact_ number of non-zeros per row (using a
>>> running list in Fortran) by looping over nodes & elements, the code takes 17
>>> mins (to calculate nnz's/per row, assemble and solve).
>>> 2. If I dont use a running list and simply get the average of the max
>>> number of nodes a node might be connected to (again by looping over nodes &
>>> elements but not using a running list) then it takes 8 mins
>>> 3. If I just magically guess the right value calculated in 2 and use that
>>> as average nnz per row then it only takes 25 secs.
>>> Basically in all cases Assembly and Solve are very fast (few seconds) but
>>> the nnz calculation itself (in 2 and 3) takes a long time. How can this be
>>> cut down? Is there a heuristic way to estimate the number (as done in 3)
>>> even if it slightly overestimates the nnz's per row or are efficient ways to
>>> do step 1 or 2. Right now I have do i=1,num_nodes; do j=1,num_elements ...
>>> which obviously is slow for large number of nodes/elements.
>>  If you want to see my code doing this, look at
>>    include/petscdmmesh.hh:preallocateOperatorNew()
>>  which handles the determination of nonzero structure for a FEM operator.
>> It should look mostly
>> like your own code.
>>      Matt
>>> Thanks in advance
>>>  Tabrez
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110517/a5000b64/attachment.htm>
