[petsc-users] nonzero prescribed boundary condition
Jed Brown jed at 59A2.org
Thu May 12 05:41:41 CDT 2011
On Thu, May 12, 2011 at 06:35, Tian(ICT) <rongtian at ncic.ac.cn> wrote:
> Without any option, SNES converges never calling FormJacobian,
> and the solution seems correct.
> What is the reason for that the SNES solver never calls FormJacobian (mf
> option was not used)?
Please send the following:
1. The code where you configure the solver, everything from SNESCreate to
SNESSolve
2. The complete command line that you run with.
3. Output when you add "-snes_view -options_table" to the command line
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110512/34575998/attachment.htm>
