[petsc-users] PetscSortRealWithPermutation causes segfaults
S V N Vishwanathan vishy at stat.purdue.edu
Fri May 6 11:59:01 CDT 2011
> This issue of hitting worst case of quicksort came up before with
> PetscSortInt. It would be interesting to know if the pivot selection
> in PetscSortInt_Private would fix the worst-case behavior that you
> see? If so, then the same changes could be made to the other sorting
> routines.
I did a bit more investigation and found that this worst case is
happening when all the elements of the array are the same. I am
detecting this in my code and avoid calling the sort as a stop gap
measure.
I don't think there will be trouble with a O(n) memory in a queue but a
recursive call overflows the stack.
vishy
