[petsc-users] PetscSortRealWithPermutation causes segfaults
S V N Vishwanathan vishy at stat.purdue.edu
Fri May 6 00:37:50 CDT 2011
Hi
I am using PetscSortRealWithPermutation to sort an array with around
200K elements and it causes a segfault.
STL sort is able to handle this array without any problems.
I looked at the gdb backtrace. It primarily seems to be because the
stack is exhausted because of recursive calls to
PetscSortRealWithPermutation_Private. I am wondering if it might not be
a better idea to implement PetscSortRealWithPermutation_Private without
recursion to avoid these errors?
vishy
