[petsc-users] Preallocation (Unstructured FE)
Sun May 1 09:53:14 CDT 2011
On Sat, Apr 30, 2011 at 12:58 PM, Tabrez Ali <stali at geology.wisc.edu> wrote:
> Petsc Developers/Users
> I having some performance issues with preallocation in a fully unstructured
> FE code. It would be very helpful if those using FE codes can comment.
> For a problem of size 100K nodes and 600K tet elements (on 1 cpu)
> 1. If I calculate the _exact_ number of non-zeros per row (using a running
> list in Fortran) by looping over nodes & elements, the code takes 17 mins
> (to calculate nnz's/per row, assemble and solve).
> 2. If I dont use a running list and simply get the average of the max
> number of nodes a node might be connected to (again by looping over nodes &
> elements but not using a running list) then it takes 8 mins
> 3. If I just magically guess the right value calculated in 2 and use that
> as average nnz per row then it only takes 25 secs.
> Basically in all cases Assembly and Solve are very fast (few seconds) but
> the nnz calculation itself (in 2 and 3) takes a long time. How can this be
> cut down? Is there a heuristic way to estimate the number (as done in 3)
> even if it slightly overestimates the nnz's per row or are efficient ways to
> do step 1 or 2. Right now I have do i=1,num_nodes; do j=1,num_elements ...
> which obviously is slow for large number of nodes/elements.
If you want to see my code doing this, look at
  include/petscdmmesh.hh:preallocateOperatorNew()
which handles the determination of nonzero structure for a FEM operator. It
should look mostly
like your own code.
    Matt
> Thanks in advance
> Tabrez
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110501/18149b8d/attachment.htm>
