[petsc-users] strange and slow behavior when using KSPSolve
Alejandro Marcos Aragón alejandro.aragon at gmail.com
Thu Mar 31 10:19:26 CDT 2011
Hi all,
I am currently using PETSc to solve a system of linear equations in parallel, so I created a wrapper class that interfaces my C++ code with the PETSc library.
Since the problem I'm trying to solve is nonlinear, I assemble the matrix once and I reuse the structure (the sparsity pattern is the same). The problem is that after a few times of solving the system very fast, it suddenly takes a considerable amount of time and I really don't understand why this is happening.
This is an extract of the code showing the timing issue that I have just before solving the system with 2 processes:
[0] Inside PETSc solver:7.15256e-06 s
[0]   Got ownership range... 3.21865e-05 s
Inside PETSc solver:1.5974e-05 s
[1]   Got ownership range... 4.00543e-05 s
[1]   Zeroed-out sparse matrix entries... [0]   Zeroed-out sparse matrix entries... 0.000444174 s
0.000442982 s
[1]   Filled sparse matrix... 0.0772262 s
[0]   Filled sparse matrix... 0.081254 s
[1]   Sparse matrix assembled... 0.0897892 s
[0]   Sparse matrix assembled... 0.0954142 s
[0]   Vectors created... 0.0955811 s[1]   Vectors created... 0.095592 s
[0]   Right hand side set... 0.0965121 s
[1]   Right hand side set... 0.0965312 s
[0]   Right-hand-side vector assembled... 0.096647 s
[1]   Right-hand-side vector assembled... 0.096657 s
[0]   System solved... 32.6188 s
[1]   System solved... 32.6188 s
[0]   Solution vector scattered... [1]   Solution vector scattered... 32.6192 s
32.6192 s
[1]   Solution vector copied... 32.6215[0]   Solution vector copied... 32.6215 s
 s
[1]   Temporary data structures destroyed... 32.6216 s[0]   Temporary data structures destroyed... 32.6216 s
So you can see that it takes a considerable amount of time to solve the system at this point, when usually this is what I get:
[0]   Right-hand-side vector assembled... 0.089427 s
[1]   Right-hand-side vector assembled... 0.089438 s
[0]   System solved... 0.383509 s
[1]   System solved... 0.38352 s
Does anyone know why this is happening? Thanks in advance for any insight on this.
Alejandro M. Aragón
P.S.: The code I use is given below:
	struct PETSc_solver {
        	typedef doVERBOSEuble value_type;
		typedef sparse_vector<value_type> sparse_vector_type;
		typedef sparse_matrix<value_type> sparse_matrix_type;
        int argc_;
        char **args_;
        Mat A_;              //!< linear system matrix
        Vec x_;              //!< Solution vector
        KSP ksp_;            //!< linear solver context
        bool allocated_;
		PETSc_solver() : argc_(), args_(NULL), allocated_(false) {
            PetscInitialize(&argc_,&args_,NULL,NULL);
            PetscErrorCode ierr = MatCreate(PETSC_COMM_WORLD,&A_);CHKERR(ierr);
            ierr = KSPCreate(PETSC_COMM_WORLD,&ksp_);CHKERR(ierr);
		PETSc_solver(int argc, char** args) : argc_(argc), args_(args) {
        //! Overload operator() to solve system of linear equations
		sparse_vector_type operator()(const sparse_matrix_type& AA, const sparse_vector_type& bb);
        ~PETSc_solver() {
            PetscErrorCode ierr = MatDestroy(A_);CHKERR(ierr);
            ierr = KSPDestroy(ksp_);CHKERR(ierr);
            ierr = VecDestroy(x_);CHKERR(ierr);
PETSc_solver::sparse_vector_type PETSc_solver::operator()(const PETSc_solver::sparse_matrix_type& AA, const PETSc_solver::sparse_vector_type& bb) {
    assert(AA.rows() == bb.size());
    Vec            x,b;      /* approx solution, RHS */
    PetscInt       Istart,Iend;
    PetscErrorCode ierr;
#ifdef VERBOSE
    cpputils::ctimer timer;
    MPIPRINT("Inside PETSc solver:" );
    cout<<timer<<endl;
#endif
    ierr = MatSetFromOptions(A_);CHKERR(ierr);
    if (!allocated_) {
#ifdef VERBOSE
        MPIPRINT("  Allocating memory... ");
        cout<<timer<<endl;
#endif
        ierr = MatSetSizes(A_,PETSC_DECIDE,PETSC_DECIDE, AA.rows(), AA.columns());CHKERR(ierr);
        // get number of non-zeros in both diagonal and non-diagonal portions of the matrix
        std::pair<size_t,size_t> nz = AA.non_zero_off_diagonal();
        ierr = MatMPIAIJSetPreallocation(A_, nz.first, PETSC_NULL, nz.second, PETSC_NULL); CHKERR(ierr);
        ierr = MatSeqAIJSetPreallocation(A_, nz.first, PETSC_NULL); CHKERR(ierr);
#ifdef VERBOSE
        cout<<"Ok! "<<timer<<endl;
#endif
     Currently, all PETSc parallel matrix formats are partitioned by
     contiguous chunks of rows across the processors.  Determine which
     rows of the matrix are locally owned.
    ierr = MatGetOwnershipRange(A_,&Istart,&Iend);CHKERR(ierr);
#ifdef VERBOSE
    MPIPRINT("  Got ownership range... ");
    cout<<timer<<endl;
#endif
    // zero-out matrix
    MatZeroEntries(A_);
#ifdef VERBOSE
    MPIPRINT("  Zeroed-out sparse matrix entries... ");
    cout<<timer<<endl;
#endif
    for (sparse_matrix_type::const_hash_iterator it = AA.map_.begin(); it != AA.map_.end(); ++it) {
        // get subscripts
        std::pair<size_t,size_t> subs = AA.unhash(it->first);
        int row = subs.first;
        int col = subs.second;
        ierr = MatSetValues(A_, 1, &row, 1, &col, &it->second, ADD_VALUES);CHKERR(ierr);
#ifdef VERBOSE
    MPIPRINT("  Filled sparse matrix... ");
    cout<<timer<<endl;
#endif
     Assemble matrix, using the 2-step process:
     MatAssemblyBegin(), MatAssemblyEnd()
     Computations can be done while messages are in transition
     by placing code between these two statements.
    ierr = MatAssemblyBegin(A_,MAT_FINAL_ASSEMBLY);CHKERR(ierr);
    ierr = MatAssemblyEnd(A_,MAT_FINAL_ASSEMBLY);CHKERR(ierr);
#ifdef VERBOSE
    MPIPRINT("  Sparse matrix assembled... ");
    cout<<timer<<endl;
#endif
    ierr = MatSetOption(A_, MAT_NEW_NONZERO_LOCATIONS, PETSC_FALSE);CHKERR(ierr);
    /* Create parallel vectors. */
    ierr = VecCreate(PETSC_COMM_WORLD,&b);CHKERR(ierr);
    ierr = VecSetSizes(b,PETSC_DECIDE, bb.size());CHKERR(ierr);
    ierr = VecSetFromOptions(b);CHKERR(ierr);
    if (!allocated_) {
        ierr = VecDuplicate(b,&x_);CHKERR(ierr);
        // set flag to true
        allocated_ = true;
    VecZeroEntries(x_);
#ifdef VERBOSE
    MPIPRINT("  Vectors created... ");
    cout<<timer<<endl;
#endif
    /* Set hight-hand-side vector */
    for (sparse_vector_type::const_hash_iterator it = bb.map_.begin(); it != bb.map_.end(); ++it) {
        int row = it->first;
        ierr = VecSetValues(b, 1, &row, &it->second, ADD_VALUES);
#ifdef VERBOSE
    MPIPRINT("  Right hand side set... ");
    cout<<timer<<endl;
#endif
     Assemble vector, using the 2-step process:
     VecAssemblyBegin(), VecAssemblyEnd()
    ierr = VecAssemblyBegin(b);CHKERR(ierr);
    ierr = VecAssemblyEnd(b);CHKERR(ierr);
#ifdef VERBOSE
    MPIPRINT("  Right-hand-side vector assembled... ");
    cout<<timer<<endl;
#endif
     Set operators. Here the matrix that defines the linear system
     also serves as the preconditioning matrix.
    ierr = KSPSetOperators(ksp_,A_,A_,SAME_NONZERO_PATTERN);CHKERR(ierr);
     Solve the linear system
    ierr = KSPSolve(ksp_,b,x_);CHKERR(ierr);
#ifdef VERBOSE
    MPIPRINT("  System solved... ");
    cout<<timer<<endl;
#endif
     Check solution and clean up
    VecScatter ctx;
    Vec x_all;
    ierr = VecScatterCreateToAll(x_, &ctx, &x_all);CHKERR(ierr);
    ierr = VecScatterBegin(ctx,x_,x_all,INSERT_VALUES,SCATTER_FORWARD);CHKERR(ierr);
    ierr = VecScatterEnd(ctx,x_,x_all,INSERT_VALUES,SCATTER_FORWARD);CHKERR(ierr);
#ifdef VERBOSE
    MPIPRINT("  Solution vector scattered... ");
    cout<<timer<<endl;
#endif
     Get values from solution and store them in the object that will be
     returned
    sparse_vector_type xx(bb.size());
    /* Set solution vector */
        ierr = VecGetValues(x_all, 1, &row, &xx[row]);
#ifdef VERBOSE
    MPIPRINT("  Solution vector copied... ");
    cout<<timer<<endl;
#endif
    ierr = VecDestroy(b);CHKERR(ierr);
    ierr = VecDestroy(x_all);CHKERR(ierr);
#ifdef VERBOSE
    MPIPRINT("  Temporary data structures destroyed... ");
    cout<<timer<<endl;
#endif
    return xx;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110331/aa4bf1d9/attachment-0001.htm>
