[petsc-users] Which preconditioners are scalable?
Fri Mar 11 10:56:12 CST 2011
On Fri, Mar 11, 2011 at 9:52 AM, Sebastian Steiger <steiger at purdue.edu>wrote:
> Hello PETSc developers
> I'm doing some scaling benchmarks and I found that the parallel asm
> preconditioner, my favorite preconditioner, has a limit in the number of
> cores it can handle.
> I am doing a numerical experiment where I scale up the size of my matrix
> by roughly the same factor as the number of CPUs employed. When I look
> at which function used how much memory using PETSc's routine
> PetscMallocDumpLog, I see the following:
> Function name                        N=300         N=600     increase
> MatGetSubMatrices_MPIAIJ_Local    75'912'016   134'516'928    1.77
> MatIncreaseOverlap_MPIAIJ_Once    168'288'288  346'870'832    2.06
> MatIncreaseOverlap_MPIAIJ_Receive  2'918'960     5'658'160    1.94
> The matrix sizes are 6'899'904 and 14'224'896, respectively. Above
> N~5000 CPUs I am running out of memory.
We have run ASM on 224,000 processors of the XT5 at ORNL, so something else
is going on here. The best thing to do here is send us -log_summary. For
attachments,
we usually recommend petsc-maint at mcs.anl.gov.
   Matt
> Here's my question now: Is the asm preconditioner limited from the
> algorithm point of view, or is it the implementation? I thought that
> 'only' the local matrices, plus some constant overlap with neighbors,
> are solved, so that memory consumption should stay constant when I scale
> up with a constant number of rows per process.
> Best
> Sebastian
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110311/1ad31f7a/attachment.htm>
