[petsc-users] eigenvalues in a band
Umut Tabak u.tabak at tudelft.nl
Sat Jun 25 10:22:46 CDT 2011
>    The report is the same as the ACM paper.
>     We can share the code with you but it is a little fragile and you may need to do a little work to get it going for your problems.
>     Barry
That would be perfect and I will refer to that paper in my publication
if I can make it get published ;)
How should I continue to get the code and start testing the code?
Best wishes,
Umut
