[petsc-users] Error for ilu
Shri abhyshr at mcs.anl.gov
Tue Jun 21 14:19:12 CDT 2011
Thanks for the patch. I tried to run the code but it spews an error
Undefined symbols:
"MatMFFDSetBase_MFFD(_p_Mat*, _p_Vec*, _p_Vec*)", referenced from:
MatAssemblyEnd_SNESMF(_p_Mat*, MatAssemblyType) in libpetsc.a(snesmfj.o)
_MatMFFDSetBase_SNESMF in libpetsc.a(snesmfj.o)
make test is also giving the same error
----- Original Message -----
On Tue, Jun 21, 2011 at 20:02, Shri < abhyshr at mcs.anl.gov > wrote:
The error message is indeed confusing. Perhaps a better error message would be 'Cannot use -pc_type ilu with mumps'.
Did you try with the patch I pushed 45 minutes ago?
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: Matrix type seqaij symbolic ILU using solver package mumps!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110621/563e51fc/attachment.htm>
