[petsc-users] Error in VecGetArrayF90 and MatGetArrayF90
Alexander Grayver agrayver at gfz-potsdam.de
Fri Jun 17 06:18:04 CDT 2011
I find it strange that in the documentation of MatGetArrayF90 you write:
Synopsis
/MatGetArrayF90(Mat x,{Scalar, pointer :: xx_v(:)},integer ierr)/
Which doesn't compile:
/Error    1     Error: The shape matching rules of actual arguments and
dummy arguments have been violated.   [xx_v]/
What really works is
/MatGetArrayF90(Mat x,{Scalar, pointer :: xx_v(:,:)},integer ierr)/
On 17.06.2011 12:50, Alexander Grayver wrote:
> Sorry Jed, t was my fault.
> I had to include:
> #include "finclude/petscvec.h90"
> #include "finclude/petscmat.h90"
> I read about that in documentation 3 months ago and forgot to do that
> in new module.
> On 17.06.2011 12:23, Jed Brown wrote:
>> On Fri, Jun 17, 2011 at 12:05, Alexander Grayver
>> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>>     What is ABI?
>> Application Binary Interface, basically the assembly-level calling
>> semantics. If the tests run successfully, then this is not the problem.
>>     Both examples work without crashing. Pretty weird...
>> One more to try: mat/examples/tests/ex16f90.F
>>     I can tell more. I found place in my code, just different fortran
>>     module, where VecGetArrayF90 works both on seq and mpi vectors.
>> This call works from one Fortran module, but not from another? I
>> suspect stack corruption, perhaps from something as simple as the
>> wrong number of arguments to an earlier call. (Fortran having nearly
>> worthless type checking.)
>>     What API do you mean exactly?
>> The non-F90 VecGetArray() and MatGetArray(). But if MatGetArrayF90()
>> is working when called in a different context, then this shouldn't be
>> necessary.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110617/661c505d/attachment.htm>
