[petsc-users] Error in VecGetArrayF90 and MatGetArrayF90
Alexander Grayver agrayver at gfz-potsdam.de
Fri Jun 17 05:05:29 CDT 2011
On 17.06.2011 12:00, Jed Brown wrote:
> On Fri, Jun 17, 2011 at 11:42, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     Hello!
>     I use petsc-3.1.7 on Windows x64 and Intel Fortran Compiler 10.1.
>     Whenever I call VecGetArrayF90/MatGetArrayF90 it crashes.
> Hmm, maybe Intel Fortran has a different ABI for pointer parameters on
> 64-bit Windows.
What is ABI?
> Does this examples also crash?
> src/vec/vec/examples/tutorials/ex4f90.F
> If this doesn't work, then someone will need to learn what the ABI is
> so that the F90 wrappers work.
> How about this one (using F77 arrays)?
> src/mat/examples/tests/ex36f.F
Both examples work without crashing. Pretty weird...
I can tell more. I found place in my code, just different fortran
module, where VecGetArrayF90 works both on seq and mpi vectors.
> As a short-term solution, perhaps you can use this API?
What API do you mean exactly?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110617/b3fb8c5d/attachment.htm>
