[petsc-users] Some papers for additive schwarz and blocked jacobi?
Dürrwang, Jürgen Juergen.Duerrwang at iosb.fraunhofer.de
Mon Jun 6 07:53:45 CDT 2011
for help, I have read both algorithms in Saad. My main problem in understanding of the procedure is how the decompose the domain. At the moment I decompose with jacobi block method(without overlapping) and I run on each block LIU(0) in parallel after that I put each solution together for an CG solver. With that my iteration number raises instead of break down, so there must be something wrong :).
Perhaps you know the order of the methods? First Jacobi-block then additive-Schwarz then ILU(0) and at least cg loop, or is it another order?
Kind regards
Jürgen Dürrwang
Von: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] Im Auftrag von Matthew Knepley
Gesendet: Montag, 6. Juni 2011 09:39
An: PETSc users list
Betreff: Re: [petsc-users] Some papers for additive schwarz and blocked jacobi?
2011/6/6 Dürrwang, Jürgen <Juergen.Duerrwang at iosb.fraunhofer.de<mailto:Juergen.Duerrwang at iosb.fraunhofer.de>>
I am working on a NVIDIA CUDA improved cg solver, with fast preconditioning. Since I have tested PETSC PCJACOBI with ILU(0) on each block I have some nice results. Unfortunately the pc is on CPU, so I try to port them on GPU. Now my question is, has body some material about this PETSC implementation?
The ILU(0) algorithm is described in Yousef Saad's book on Iterative Methods. It is notoriously hard to parallelize.
ASM and Block-Jacobi jsut decompose the system into blocks. They are also described in the book.
   Matt
Kind regards,
Jürgen Dürrwang
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110606/ff4b05c8/attachment.htm>
