[petsc-users] A question on "memory access out of range" in mpi running
zhenglun.wei at gmail.com zhenglun.wei at gmail.com
Wed Jun 1 11:57:57 CDT 2011
Thanks Matt,
Do I need to comment out the whole function of VTK, or just certain line(s)?
Alan
On Jun 1, 2011 11:50am, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jun 1, 2011 at 11:47 AM, Alan Wei zhenglun.wei at gmail.com> wrote:
> Hi guys, I hope you're having a nice day.
> I was trying to run ex29.c in src/ksp/ksp/example/tutorial. It is normal
> to go through without MPI. However, with the same grid size, if I run it
> with 4 processes with MPI, a error message of "Caught signal number 11
> SEGV: Segmentation Violation, probably memory access out of range" will
> show up. Did anyone have this kind of issue before. I guess this is
> probably caused by the way I launched the 'mpiexec'. Any idea on it? The
> full error message is attached.
> Thanks in advance.
> No, there is some problem with the VTK output for that. You can comment
> it out. I will look at fixing it.
> Matt
> best,
> Alan
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110601/973475f7/attachment-0001.htm>
