[petsc-users] Makefile on Photran with PETSc in linux
TAY wee-beng zonexo at gmail.com
Wed Jan 19 05:09:41 CST 2011
I can compile with PETSc on linux with the makefile provided by the
PETSc team. I'm now trying to use photran. I have made a makefile which
is very basic and it basically list out all the commands to run. It can
be used to compile on photran.
However, I hope to use the makefile provided by the PETSc team because
it is much more flexible. However when I use it, it says:
**** Build of configuration Default for project ibm2d_high_Re ****
make all
make: *** No rule to make target `all'.  Stop.
I have attached the 2 makefiles:
Makefile - from PETSc team
Makefile_old - my own makefile
Yours sincerely,
TAY wee-beng
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110119/3c85f22a/attachment.diff>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110119/3c85f22a/attachment-0001.diff>
