[petsc-users] Infinite or not-a-number generated in norm!
Fri Dec 30 16:45:52 CST 2011
On Fri, Dec 30, 2011 at 16:43, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> Sounds very useful, will check it out once the next patch is out, thanks!
It's not going to be ported to petsc-3.2. Use petsc-dev if you want this.
(There aren't many changes yet, so it's easy to migrate from petsc-3.2 to
petsc-dev: http://www.mcs.anl.gov/petsc/documentation/changes/dev.html)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111230/8b7d4ac2/attachment.htm>
