[petsc-users] Infinite or not-a-number generated in norm!
Fri Dec 30 10:44:31 CST 2011
On Fri, Dec 30, 2011 at 10:34, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> Very useful hint that with -fp_trap. I get trapped at:
> Program received signal SIGFPE, Arithmetic
> exception.0x00000000010fad4e in hypre_BoomerAMGRelax (A=0x1b56e9a0,
> f=0x195487b0,     cf_marker=0x692b900, relax_type=6, relax_points=1,
> relax_weight=1,     omega=1, l1_norms=0x0, u=0xb0f8aa0,
> Vtemp=0x18fd1900, Ztemp=0x0)    at par_relax.c:19251925
>       u_data[i] = res / A_diag_data[A_diag_i[i]];
> with  res = -2.4683099805590231e+303 and A_diag_data[A_diag_i[i]] =
> 9.287739686222747e-06. The full backtrace goes through many boomeramg
> lines to point back at the end to my code where (in a custom
> preconditioner) I solve a linear system with KSPGMRES and
> PCHYPRE/boomeramg. I guess I will proceed now with inspecting the
> values by hand, but if there still are some useful Petsc tricks I am
> eager to hear.
Is your system singular? Or perhaps the BoomerAMG smoother is not stable
for your problem. You didn't show the full stack.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111230/6146b401/attachment.htm>
