[petsc-users] mumps freezes for bigger problems
Dominik Szczerba dominik at itis.ethz.ch
Sat Dec 24 11:00:16 CST 2011
Jack: I do not even have these packages installed anywhere on my system.
Barry: That's what I did, I downloaded everything via configure.
Anywhere else to look?
Dominik
On Sat, Dec 24, 2011 at 1:35 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   If you have PETSc ./configure do all the installs this decreases the chance of problems like this.  Use --download-blacs --download-scalapack --download-mumps --download-parmetis --download-ptscotch
>   Barry
> On Dec 23, 2011, at 4:56 PM, Jack Poulson wrote:
>> It looks like it's due to mixing different MPI implementations together (i.e., including the wrong 'mpif.h'):
>> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007559.html
>> If I recall correctly, MUMPS only uses ScaLAPACK to factor the root separator when it is sufficiently large, and that would explain why it works for him for smaller problems. I would double check that ScaLAPACK, PETSc, and MUMPS are all compiled with the same MPI implementation.
>> Jack
>> On Wed, Dec 21, 2011 at 4:55 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>> Hailong:
>> I've never seen this type of error from MUMPS.
>> It seems programming bug. Are you sure smaller problem runs correctly?
>> Use valgrind check it.
>> Hong
>> > I got the error from MUMPS.
>> > When I run MUMPS (which requring scalapack) with matrix size (n) = 30620,
>> > nonzeros (nz) = 785860,
>> > I could run it. And could get result.
>> > But when I run it with
>> > nz=3112820
>> > n =61240
>> > I am getting the following error
>> > 17 - <NO ERROR MESSAGE> : Could not convert index 1140850688 into a pointer
>> > The index may be an incorrect argument.
>> > Possible sources of this problem are a missing "include 'mpif.h'",
>> > a misspelled MPI object (e.g., MPI_COM_WORLD instead of MPI_COMM_WORLD)
>> > or a misspelled user variable for an MPI object (e.g.,
>> > com instead of comm).
>> > [17] [] Aborting Program!
>> > Do you know what happened?
>> > Is that possible it is running out of memory?
>> > On Wed, Dec 21, 2011 at 7:15 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>> >> Direct solvers often require large memory for storing matrix factors.
>> >> As Jed suggests, you may try superlu_dist.
>> >> With mumps, I notice you use parallel analysis, which is relative new in
>> >> mumps.
>> >> What happens if you use default sequential analysis with
>> >> different matrix orderings?
>> >> I usually use matrix ordering '-mat_mumps_icntl_7 2'.
>> >> Also, you can increase fill ratio,
>> >> -mat_mumps_icntl_14 <20>: ICNTL(14): percentage of estimated workspace
>> >> increase (None)
>> >> i.e., default ration is 20, you may try 50? (I notice that you already use
>> >> 30).
>> >> It seems you use 16 CPUs for "a mere couple thousands
>> >> elements" problems, and mumps "silently freezes". I do not have this type
>> >> of experience with mumps. I usually can solve sparse matrix of size
>> >> 10k with 1 cpu using mumps.
>> >> When mumps runs out of memory or gets other problems, it terminates
>> >> execution and dumps out error message,
>> >> not freezes.
>> >> Something is wrong here. Use a debugger and figuring out where it freezes.
>> >> Hong
>> >> On Wed, Dec 21, 2011 at 7:01 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> >> > -pc_type lu -pc_factor_mat_solver_package superlu_dist
>> >> > On Dec 21, 2011 6:19 AM, "Dominik Szczerba" <dominik at itis.ethz.ch>
>> >> > wrote:
>> >> >> I am successfully solving my indefinite systems with MUMPS but only
>> >> >> for very small problems. To give a feeling, a mere couple thousands
>> >> >> elements. If I only double the problem size, it silently freezes, even
>> >> >> with max verbosity via the control parameters. Did anyone succeed here
>> >> >> with big problems? Any recommendations for a drop-in replacement for
>> >> >> MUMPS?
>> >> >> Thanks for any hints,
>> >> >> Dominik
>> >> >> Options used:
>> >> >> -mat_mumps_icntl_4 3 -mat_mumps_icntl_28 2 -mat_mumps_icntl_29
>> >> >> Output:
>> >> >> ****** FACTORIZATION STEP ********
>> >> >>  GLOBAL STATISTICS PRIOR NUMERICAL FACTORIZATION ...
>> >> >>  NUMBER OF WORKING PROCESSES              =          16
>> >> >>  OUT-OF-CORE OPTION (ICNTL(22))           =           0
>> >> >>  REAL SPACE FOR FACTORS                   =  1438970073
>> >> >>  INTEGER SPACE FOR FACTORS                =    11376442
>> >> >>  MAXIMUM FRONTAL SIZE (ESTIMATED)         =       16868
>> >> >>  NUMBER OF NODES IN THE TREE              =       43676
>> >> >>  Convergence error after scaling for ONE-NORM (option 7/8)   = 0.21D+01
>> >> >>  Maximum effective relaxed size of S              =   231932340
>> >> >>  Average effective relaxed size of S              =   182366303
>> >> >>  REDISTRIB: TOTAL DATA LOCAL/SENT         =     1509215    22859750
>> >> >>  GLOBAL TIME FOR MATRIX DISTRIBUTION       =      0.8270
>> >> >>  ** Memory relaxation parameter ( ICNTL(14)  )            :        35
>> >> >>  ** Rank of processor needing largest memory in facto     :         0
>> >> >>  ** Space in MBYTES used by this processor for facto      :      2017
>> >> >>  ** Avg. Space in MBYTES per working proc during facto    :      1618
>> > Hailong
