[petsc-users] KSP diverging
Fri Dec 23 19:18:12 CST 2011
On Fri, Dec 23, 2011 at 7:14 PM, Mohamad M. Nasr-Azadani
<mmnasr at gmail.com>wrote:
> Thank you guys,
> What happens right now when I use GMRES is that it reaches the maximum
> number of iterations I set, i.e. 1000 (which should not). I have set the
> restart to 20 (and then increased it to 1000) but no luck. It never
> converges.
It sounds like your operator is singular.
   Matt
> On Fri, Dec 23, 2011 at 7:23 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Fri, Dec 23, 2011 at 07:43, Matthew Knepley <knepley at gmail.com> wrote:
>>> Even if you lose orthogonality, it will just stagnate since you always
>>> have the solution
>>> from the first few vectors. Likewise, I do not see how you can get an
>>> diverging sequence
>>> from restarting since you always have the last residual, you just
>>> stagnate.
>> The true residual can grow even though the estimate of the preconditioned
>> residual decreases monotonically. When you restart, you re-evaluate the
>> actual residual, which might be much larger.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111223/ace04d12/attachment.htm>
