[petsc-users] error attaching debugger (again)
Fri Dec 23 16:04:26 CST 2011
On Fri, Dec 23, 2011 at 15:55, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> xtern and other x11 apps were fine as well as xtern and ssh
> forwarding. I once had to add -display for the very same error. But
> now somehow removing it brings xterms up again... Strainge...
I changed the default a year or two ago so that it work work on most
"normally configured" systems.
It might work if you specify "-display :0" (instead of "-display :0.0"),
but if the default works without a -display argument, that's great.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111223/062e3ec7/attachment.htm>
